Program too big to fit in memory?
   15809   13   0
i downloaded H9 for windowsxp through the download page, however when i try to run the installer, it reprots:“Program too big to fit in memory”
the version is 9.0.653
and version 8 installer runs fine on my pc.
I have tried on several machines with the same problem. I have also tried “run as” which spits out an error that the program can't create a file in the user/local settings/Temp directory….sure which I could check it out
Do you guys have administrator privileges in your login?
yes, I have tried it at home on my workgroup and at work on a domain, all with admin privileges…the “run as” was just a shot in the dark really….I am hoping it may be a bad build but I am surprised more people aren't having this issue
You don't a have a setup where you're installing to a remote directory right? I've installed it on Vista 32-bit without any particular problems but this was about a month or so back.
Hmmm …. Make sure you have the complete file? How are you downloading it?
edward
from here:
http://www.sidefx.com/index.php?option=com_download&task=apprentice&Itemid=89 [sidefx.com]
about the remote path thing, that could the problem.
you see, at work all our “documents and settings/user/” is mapped to a network drive which houdini is trying to access while install?
and at home, all settings are local which is all normal setups except that i downloaded the installer at another computer and was trying to install it across the network.
anyways, nothing much i can do at the work PC, but i will try to copy the installer to the local machine then install it at home today.
i will post the result tonight. thx
Well I do have “My Documents” stored on a separate drive but I am installing locally and everything is pretty standard windows 32 bit install. I have tried it on pentium and AMD both with 2gigs RAM
I have downloaded the file from same place mentioned above with IE, firefox, and flashgot….all with the same result. I have tried disabling virus protection and firewalls also.
The behavior I see is that a command window appears briefly then quits…..when I change the properties of the dos tab on the executable to not close on error then I can see the “too big to fit in memory” error
has anyone installed this recently with success?
Any chance of trying a different build? Current build is houdini-9.0.653-win32
thanks for the feedback and trying to help
It might be a good idea to check the download's MD5 and compare it to the one on the Downloads [sidefx.com] page which has the most recent builds.
You can download a MD5sum tool here [pc-tools.net].
Also, are you using Service Pack 2?
Cheers!
steven
Ok….I am working now…thanks Steven
I did the MD5 check and the sums are different so something is busted there. However, I downloaded build houdini-9.0.677-win32 from the link you sent and that worked no problem….must be and issue in that build.
thanks for your help and tell Val that I (Justin) say hi…he is at Imageworks as a Houdini artist also. Now that I can learn Houdini I may be there myself at some point :wink:
You're welcome! I'll tell him when I see him.
Cheers!
steven
still no luck for me either. can the admin of the web check 9.0.653 on the download page? i dont think the that installer is working.
also where can i download houdini-9.0.677-win32?
follow the link on Stevens 2nd-to-last post :roll:
Please use vim or ultraedit to remove the first line in the file you downloaded.
Obviously, the download page has outputed extra text “Trying to download 9.0 653 win32 exe <br/>”.
pinxue
Should be fixed now, thanks.
