Hi everyone.
I started using Houdini recently and I'd like to install Redshift on it as a render engine. I'm working on Houdini 19.5.493, I would like to know which version of Redshift do I need.
https://redshift.maxon.net/topic/31230/houdini-solaris-plugins-custom-builds [redshift.maxon.net]
I found this topic where it's possible to download the correct plugin for the proper versiob. My doubt is: this plugin just works on 3.5.12 or it can works also on the versions above it (ex. Redshift 3.5.15).
Thank you in avance.
Redshift - Houdini compatibility
14315 2 3-
- iakkm
- 2 posts
- cdordelly
- 207 posts
Hello!
In this link you will be able to find the current supported builds from each RS version:
https://help.maxon.net/r3d/houdini/en-us/index.html#html/Houdini+Plugin+Configuration.html#Plugin [help.maxon.net]
Hope that helps, cheers!
- TwinSnakes007
- 650 posts
