Position value of input object is inconsistent when heightfield_project is applied
Hello, there is a problem that the project location does not match when applying heightfield_project in Houdini Engine for Unreal. may i know how to solve it?😟
Position value mismatch when heightfield_project is applied
1906 1 1-
- iasm6419
- 10 posts
- iasm6419
- 10 posts
I solved the problem.
Solution in my case
1_Set the heightfield map size of the Houdini engine in the same range as the Unreal Landscape size
2_When Houdini Asset is placed in the scene, Houdini Asset's coordinates must be 0.0.0
(The instantiate at the origin function among the Houdini Asset action functions in Unreal Engine is helpful)
Solution in my case
Edited by iasm6419 - June 15, 2023 03:16:02
