How to create spline from points
3112 9 2-
- Beka
- 42 posts
- Lucca
- 42 posts
- Beka
- 42 posts
LuccaThanks Lucca!
if they happen to be in right point order just use "add" sop enabling by group under polygons tab. Or otherwise if they somehow have fitting attributes you can also use 'add' to connect them via the attribute
Problem is that I don't know the right point order.
I have not any information, only this.
- animatrix_
- 5100 posts
You can look up points in the direction of the previously found point by making an exception in the first point and limit your search to a cone angle using pcopen:
https://www.sidefx.com/docs/houdini/vex/functions/pcopen.html [www.sidefx.com]
Alternatively you can implement the same cone angle yourself and use the newer pcfind VEX functions.
- Beka
- 42 posts
animatrix_Thank you!
I thought something similar and probably it is the only way. I can not see how can I transfer cone information into pcopen(), but now I've found function of pccone() which can get direction and cone angle, (Wow I don't know that function). I think it will be difficult in the corner area, but yeah it will be good starting point
- cncverkstad
- 173 posts
- Beka
- 42 posts
cncverkstadThank you so much!sort by index and Add.float pos_arr[] = {}; for(int i=0;i<@numpt;i++) { vector p = point(0, "P", i); push(pos_arr, p.z); } int ordering[] = argsort(pos_arr); ordering = reverse(ordering); for(int i=0;i<@numpt;i++) { setpointattrib(0, "sort_index", ordering[i], i); }
It has problem when curve turns around
- cncverkstad
- 173 posts
For that you can use
Euclidean Minimum Spanning Tree by Satoru Yonekura that I got those codes from.
Clean
Convertline
detail wrangle
blast not newedge
Have Fun
foreach(int pt; nearpoints(0, @P, 1.0, 10)) { if(pt == @ptnum) continue; vector p = point(0, 'P', pt); float dist = distance(p, @P); int ptsA[] = nearpoints(0, @P, dist); int ptsB[] = nearpoints(0, p, dist); int chk = 0; foreach(int cpt; ptsB) { if(cpt == @ptnum || cpt == pt) continue; chk = removevalue(ptsA, cpt); if(chk) break; } if(!chk) { int pr = addprim(0, 'polyline'); addvertex(0, pr, @ptnum); addvertex(0, pr, pt); } }
Convertline
detail wrangle
int ptlist[]; for(int pt=0; pt<@numpt; pt++) push(ptlist, pt); int newlist[]; push(newlist, 0); removevalue(ptlist, 0); while(len(ptlist) > 0) { float mindist = 10000; int newpt = -1; int newedge = -1; foreach(int pt; newlist) { foreach(int prim; pointprims(0, pt)) { int targetpt = primpoint(0, prim, 0); if(targetpt == pt) targetpt = primpoint(0, prim, 1); if(find(newlist, targetpt) > -1) continue; float dist = prim(0, 'restlength', prim); if(dist <= mindist) { mindist = dist; newpt = targetpt; newedge = prim; } } } if(newpt == -1) break; push(newlist, newpt); removevalue(ptlist, newpt); setprimgroup(0, 'newedge', newedge, 1); }
blast not newedge
Have Fun
Edited by cncverkstad - Sept. 5, 2023 12:09:31
Conservation of Momentum
- Beka
- 42 posts
cncverkstadWow it works! amazing!
Euclidean Minimum Spanning Tree by Satoru Yonekura that I got those codes from.Cleanforeach(int pt; nearpoints(0, @P, 1.0, 10)) { if(pt == @ptnum) continue; vector p = point(0, 'P', pt); float dist = distance(p, @P); int ptsA[] = nearpoints(0, @P, dist); int ptsB[] = nearpoints(0, p, dist); int chk = 0; foreach(int cpt; ptsB) { if(cpt == @ptnum || cpt == pt) continue; chk = removevalue(ptsA, cpt); if(chk) break; } if(!chk) { int pr = addprim(0, 'polyline'); addvertex(0, pr, @ptnum); addvertex(0, pr, pt); } }
Convertline
detail wrangleint ptlist[]; for(int pt=0; pt<@numpt; pt++) push(ptlist, pt); int newlist[]; push(newlist, 0); removevalue(ptlist, 0); while(len(ptlist) > 0) { float mindist = 10000; int newpt = -1; int newedge = -1; foreach(int pt; newlist) { foreach(int prim; pointprims(0, pt)) { int targetpt = primpoint(0, prim, 0); if(targetpt == pt) targetpt = primpoint(0, prim, 1); if(find(newlist, targetpt) > -1) continue; float dist = prim(0, 'restlength', prim); if(dist <= mindist) { mindist = dist; newpt = targetpt; newedge = prim; } } } if(newpt == -1) break; push(newlist, newpt); removevalue(ptlist, newpt); setprimgroup(0, 'newedge', newedge, 1); }
blast not newedge
Have Fun
Only the areas where I have harsh edges have a problem, but the rest is great!
Thank you!
- cncverkstad
- 173 posts
