Global defaults for Digital Asset Save Preferences
   1039   0   1
I've been trying to set some studio wide defaults for the Digital Asset Save Preferences without much luck so far. Specifically i've tried using the same approach as discussed for other config files here [www.sidefx.com] for `vhda.config` which contains the required settings. I've tried appending `.nosave` as suggested, which works fine for `hopmanager.pref` for example, but `vhda.config` doesn't seem to be getting picked up either with or without that. I'm adding the config file to the `HOUDINI_PATH` alongside `hopmanager.pref` which is working correctly.
Is it possible to set global defaults for this dialog? I'm currently working on Houdini 19.5.682.
Thanks,
Jon
