How do I add wind resistance to a simulation?
   2280   4   1
Hey! I'm working on a simple simulation:
It's based on an RBD Bullet Solver. My geometry-level node tree looks like this:
I understand that everything in Houdini is essentially running in a vacuum by default. Is there any way to add wind resistance to this simulation so that it isn't falling straight down?
Double-click on the rbdbulletsolver1 node to dive inside. Drop down a popwind node and connect it to PRESOLVE. Set the x-axis value to -1. Rewind and run your simulation again to observe the effect.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
if you don't need custom wind you can also go to
RBD Solver SOP/Forces tab and turn on Drag and tweak Air Resistance as well as simple wind direction etc.
Edited by tamte - Oct. 2, 2023 13:51:56
tamte
Just as a ballpark estimate, what should my parameters be set to? I'm currently using these, but it seems that the model explodes before hitting the ground:
Also, the model still falls straight down.
kathal-2_EXE031_V2.hipnc (1.2 MB)
Here's an example that works. I threw away all your nodes and rebuilt it. Some parameter was messed up in your setup. Don't know which one. When in doubt, it is very common to rebuild a network.
Edited by Enivob - Oct. 5, 2023 08:57:42
ap_kathal-2_EXE031_V2.hipnc (1.0 MB)
