Changing position based on last frame position
   1886   3   0
I am trying to procedurally animate things in Houdini, using similar logic as in Unity, moving the object based on its position from last update, i.e., NewPosition = OldPosition + Direction * Coefficient. (The direction vector uses a sequence of weighted input so it's really hard to convert the entire thing into integral)
Using the Vex code below inspired by this post:
vector @posRecord[];
if (@Frame == 1)
    @P = {0, 0, 0};
else
    vector lastPos = @posRecord[len(@posRecord) - 1];
    v@lastRead = lastPos;
    @P = lastPos + @N * 10; // @N as direction
append(@posRecord, @P);
if (len(@posRecord) > 10)
    removeindex(@posRecord, 0);
I am able to record the position, but `lastPos` cannot properly read from `@posRecord`. In Geometry Spreadsheet `lastPos` keeps being 0. As a result, the object is merely reading the `@N` as XYZ positions instead of move based on `@N`.
What is going and is there a way to fix this?
You need to be in a simulation environment to be able to feed back attribute values between frames
Like inside of Solver SOP or inside of DOPnet directly
I’m not sure what you are doing but maybe you can copy the value to some extra attribute. Then read it before you change it. No?
It is like monitoring if a file has changed by storing the latest timestamp in a separate variable, then you can see the difference.
Edited by SWest - Oct. 12, 2023 14:10:46
tamte
You could use forloop with feedback and animate the number of iterations with the frame number, but you might cook all of the iterations each frame. I'm not sure if it caches the last step or not.
