Hi, on Ubuntu I have set the OCIO environment variable and also put the OCIO path to houdini.env. I see correct OCIO 1.2 config file loaded in Edit>Color_settings>Color_correction. I also see in Render View in Color Correction bar that ACES+sRGB is being used but the render looks same as if OCIO is not loaded. In Windows the same OCIO config works correctly.
Additionally I am not able to drag drop any file from Nautilus into paths in the houdini nodes. I need to click the arrow and find each file in the explorer manually. Drag and drop works when I switch to GNOME Wayland but in default GNOME it does not.
Can anyone help? I spent over a day trying to fix this without luck.
Ubuntu - OCIO config + drag file into node path not working
743 0 0-
- gunjack
- 8 posts
