Can't drag keyframes in Houdini.
   2102   2   1
HI - when I'm in the basic interface and set some keyframes for a default cube - I cannot grab the green frame on the timeline and drag it to a new time position (but I see it being done in tutorials). What am I doing wrong? Thank you
If you middle-click on the timeline, a white bracket will appear. You can stretch it by grabbing the tabs on either side to extend the range. Any keyframes inside the range can be middle-dragged if to a new location, preserving the distance between frames. You must initiate the middle-drag anywhere within the tinted range. Alternately, you can middle-click-drag on an individual keyframe to relocate it on the timeline. It briefly turns red while you're dragging.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Also hold down Shift and then use left mouse to make a range selection of keys on the timeline.
