Export usd
   2141   3   0
Hi, could you please advise how to properly output animation in usd via tops?
I'm getting errors, but I can't figure out what the cause is. The test scene is attached
top_usd.hiplc (288.3 KB)
There are several ways to do this, but in this case the animations each frame is written to a single file.
top_usd_flush.hiplc (295.3 KB)
alexwheezy
Thanks, but how do I get it to render each frame to a separate file?
kornilowadd
Simply use the $F4.usd expression to save, and then load that sequence using Geometry Clip Sequence.
top_usd_flush_update.hiplc (303.3 KB)
