In H20.0, the expression language selection menu is no longer available for the entire node. Is it now only possible to change for each parameter?
[H20] Language selection menu for expressions
1918 3 1-
- dtempcyer
- 326 posts
- jsmack
- 8218 posts
I didn't know that was removed in H20 until you mentioned it. I can't find an alternative method to set the node language, maybe there's a vestigial hom method still present. I found that node language toggle to be buggy and preferred using the language flag on the actual channel. I wonder if you can still toggle the expression language globally in the preferences.
- ObeidaZakzak
- 137 posts
Don't know the reason why this menu was removed (couldn't find any info on the changelog), but there's a HOM function to do so :
hou.OpNode.setExpressionLanguage() [www.sidefx.com]
My workaround for this is to add script items to the parm gear menu Customize menus [www.sidefx.com]
- tamte
- 9492 posts
