I've been assessing Karma XPU as a replacement to third GPU renderers in Houdini, I'm loving it overall. I'm getting some mysterious errors when trying to render geometry generate by the Particle Trail sop, oddly enough it's only when I try to render a sequence. Single image viewport renders are fine, and Karma CPU renders the sequence without issue. Any ideas? Houdini 20.0.547
Error
Command Exit Code: -1073741819
Error
Failed to complete render: exit code -1073741819
Use a Log Viewer with External Render Processes enabled for more information.
Karma XPU errors
3823 4 0-
- AndyW
- 343 posts
- Enivob
- 2659 posts
- AndyW
- 343 posts
- AndyW
- 343 posts
- brians
- 597 posts
Yes, this popped up a few times in the last ~2 months, basically a CPU crash with the 545 line of drivers on Windows. Our system requirements page, and XPU documentation always report latest driver version recommendations
https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com]
https://www.sidefx.com/docs/houdini/solaris/karma_xpu.html#supported-hardware [www.sidefx.com]
"546.33+ strongly recommend for Windows"
