Hello guys,
Cannot seem to solve this myself.
I have a local transformation matrix on a point (joint).
Is there a vex way to extract the orientation in world space of this?
Getting world space orientation
2147 6 0-
- Patoz
- 10 posts
- Patoz
- 10 posts
- animatrix_
- 5100 posts
Your local transform matrix looks like identity matrix with an offset. But if it has the orientation you need, you can write something like this using a Point Wrangle:
Here I am using packed and unpacked geo.
matrix M = primintrinsic ( 1, "packedfulltransform", 0 ); @P *= invert ( M ); @P.y += ch("move"); @P *= M;
- tamte
- 9382 posts
assuming your point is part of a kinefx skeletal hierarchy you can use
Compute Transform SOP
to compute between localtransform and transform attributes
to update world (transform) attribute use explicit Compute World From Local, use Auto only if transform attrib is missing as when transform is present Auto would try to recompute localtransform
- Patoz
- 10 posts
animatrix_
Your local transform matrix looks like identity matrix with an offset. But if it has the orientation you need, you can write something like this using a Point Wrangle:matrix M = primintrinsic ( 1, "packedfulltransform", 0 ); @P *= invert ( M ); @P.y += ch("move"); @P *= M;
Thanks a lot for this
I did something similar, this is definitely cleaner but in my case is not really taking into count the local Y but would Y when I add the move to current @P....am I doing something wrong?
- animatrix_
- 5100 posts
Patozanimatrix_
Thanks a lot for this![]()
In your screenshot your matrix looks like identity matrix with an offset so that would be why the local axes align with the world axes. Maybe you can post your scene file?
- Patoz
- 10 posts
animatrix_Patozanimatrix_
My apologies turned out each of my joints stored the correct packedtransform and doing the offset of all together resulted in alignment with the world and local transform...picking them one by one did the trick
Thanks a lot for your help
