Karma properties on objects
   3680   8   2
Is there a way to set karma properties on objects (in /obj level)? I needs to flag a few objects to not show up in reflections, in redshift each object could have a tab full of options to tweaks all sorts of things.
More code, less clicks.
We're not currently providing Karma-specific control at the Object level. That said, this can be setup to work in Mantra (via the "Render Visibility" parm), and Scene Import is meant to make a Mantra scene "just work out of the box" in Karma ... so we're into valid RFE territory here
Can you try putting the attached Python script in $HOME/houdini20.0/husdplugins/objtranslatorsand see if you have any issues? It just does a straight lifting of the vm_rendervisibilityparm at the Object level and uses it to set the karma:object:rendervisibilityUSD PrimVar.
rendervis.py (676 bytes)
rendervis.hip (499.3 KB)
Brilliant, and please excuse the price winning graphics here, the blue marks aren't showing up in the reflections anymore, thx!
And the script let me to the docs, good to know it's there
https://www.sidefx.com/docs/houdini/hom/sceneimport_object_translator.html [www.sidefx.com]
Screenshot 2024-01-24 143405.jpg (76.2 KB)
Wonderful, thanks for confirming this works for you. I'll try to get it added to a Houdini build soon(ish).
Edited by robp_sidefx - Jan. 24, 2024 09:21:40
Nice!
One quick question I can't figure out.. I'm sort of missing a proper renderview to iterate renders. There is the karma viewport which is excellent for previewing the visual output but doesn't provide a way to dive into the AOVs etc. Then there is mplay which sort of does it but not really.
Call me spoiled but when doing lookdev for renders I'd like a 'Render' button and a panel that show the render output being rendered in all it's glory. Both VRay and Redshift have proper VFBs that provide a lot of useful features. Fro example I've been trying to get a simple shadowcatcher to work for over 2 hours now, I got no idea what's going on and tbh I can't even tell if that feature is even available! I've been doing CG on quite a deep technical level for over 20 years, this should be easy for me
robp_sidefx
adding properties one by one as the need comes up may not be ideal
as a workaround it could be nice to look for any known Mantra Property and translate to equivalent Karma one if applicable
however since there is a Karma ROP, to get back to the usual workflow, I think it'd a good idea to allow Karma Properties to be added, then the translators can translate them 1:1 and for artists it will feel more natural
Edited by tamte - Jan. 24, 2024 17:55:35
Jonathan de Blok
You're definitely not the first to ask for this, but I'd like to hear more definition from you about what such a thing is/isn't.
On the AOV front, there is a button that'll let you switch between AOVs.
tamte
I appreciate the frustration as/when users find flags/parms that were missed (through "this won't map to Karma" or "we don't think anyone uses this" or any other reason). I hope that we are reacting quickly enough when "I need this!" is raised by our users, be it by us providing a patch (the plugin architecture of SceneImport has really made it a lot easier for customers to wrangle their own solutions and for us to deliver experimental work to them) or adding the support in a daily build not long after.
I'll ensure this is on the radar of the relevant developers. I don't want to speak for anyone regarding the degree to which this request is/isn't aligned with their overall workflow strategy.
robp_sidefx
Jonathan de Blok
Ahh I overlooked that AV button.. thx.
I'll start a new thread about the VFB!
