How to connect Hex tiling to triplaner mapping in materialx?
   2527   6   1
I'm working on material building for USD but I'm stuck at one point. I am currently using ‘mtlxtriplanarprojection‘ and thinking of using hexTiling to get rid of Repeat. However, I'm having a hard time figuring out how to connect the nodes because there is no `texcord` input like `mtlximage`.
Can someone please help me how does it work? if there are any sample files, would be very helpful.
the hextiling has a triplanar mode, you don't use both.
Does it? I don't see any box to import maps. I am very new when it comes to houdini materialx, if you could elaborate on this, that would be great.
Edited by A-kun - Jan. 27, 2024 23:25:56
Ha-ya
You'll want the Karma Hex-Tiled Triplanar node, which has a map selection.
I don't see anymore this node Karma Hex-Tiled Triplanar node in the latest version of houdini...
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
You only see it inside the Karma Material Builder I think.
Sorry yeah, found it. i used it in the past so i was wondering... For some reason the fuzzy search tab couldn't not see it, then suddently after a restart yes... :S
Under Houdini, yes , in maxx subnetwork!
thks!
