How do I create points on the line
3313 6 1-
- feishikath
- 3 posts
- juejuezi
- 34 posts
- feishikath
- 3 posts
juejueziThank you for your reply!
delete the original line, add points and reconnect in order
I have to deal with a lot of complicated road vector lines. Each line goes in a different direction, how do I sequence it so that it successfully connects to the original direction.
Another method I tried was to calculate the length of a line and then use the refine node to add points,but there are too many segments on a broken line,I think the calculation is a little bit tedious and multiple points may be added to a line. I don't know if there are other efficient ways to do it.
One of the lines is shown here.
Thank you!
- juejuezi
- 34 posts
feishikathjuejueziThank you for your reply!
Thank you!
Since there are so many lines, what are the rules for adding points to each line?
My question is, which line to add how many points to, and based on what rules, such as length. Otherwise, I won't be able to write Vex
- made-by-geoff
- 84 posts
I think what @juejeuzi is getting at is that a little more info on what you are trying to accomplish in the big picture would be helpful. There's different ways to approach this and I might suggest one over another depending on why you want add these points, how many you need to add, and how you are determining where they should go.
You could add and use a curveu attribute to give you positions along the line so that you can add new points while maintaining the vertex order and direction of the rebuilt primitives.
But if what you're trying to ultimately do is create some kind of road builder and add branching off points for new roads that branch off from the main trunk, my mind starts going somewhere completely different. I might even start thinking about L-systems, or growth systems to create your road network.
There's lots of ways to skin a cat...
- feishikath
- 3 posts
In general, I need to merge multiple lines of road into one line. The road vector line data comes from OpenStreetMap. It may be drawn manually on the map, so it seems that there is no fixed rule.
For example, for a two-lane road, I need to first determine whether it is a two-lane road, and then I am asked to merge the corresponding points of the two-lane road.
This means that if one line has a point but the other corresponding position does not have a point, I need to add a point at that position and then merge it.
I can programmatically calculate the coordinates of where to add the point, but I can't programmatically add it to the line.
I was asked to do this, but I actually think this might not be a good idea.
As shown in the figure, the red dots are where the points need to be added, and there is also an actual road map with the lines that need to be merged marked.
- animatrix_
- 5119 posts
If you want to do this in VEX, you would have to recreate each primitive i.e. line. First you would find the adjacent points to the point to be added and then insert this point position to the list of existing point positions. Make sure to do this for all the new points first so that you don't have to recreate the same line multiple times, but only once.
If you need to preserve point, primitive, vertex attributes and groups, it gets a lot more involved since you will have to store the appropriate weight values to pass to multiple Attribute Interpolate nodes.
