supported GPU hardware for Intel OIDN in H20.5
   2383   4   0
What is the supported GPU for the intel denoiser to run on? It seems its not Nvidia (CUDA).
OIDN should support Metal and CUDA GPU devices. Some combinations of driver/GPU do not work with the CUDA device. You can check if it works on your config by running idenoise -V 1 Mandril.pic denoise.picin a Houdini shell.
If your config is not supported, you should see: OIDN: GPU device error - fall back to CPU: unsupported device type: CUDAWe hope to support more devices in the future.
yeah, I am getting that (also in the log viewer while rendering in the viewport). I am just a little surprised that an RTX A4500 with the latest drivers is not among the supported combinations. are just the ada cards supported?
mark
I get the same error with a 3090 and current drivers on Windows.
https://www.openimagedenoise.org/ [www.openimagedenoise.org] says Turing and later is supported and min driver version is 452.39 on Windows. I'm using 555.99
Edited by jsmack - July 12, 2024 20:03:35
Same error here on a 3060 with 556.12
