I'll be specific: I'm trying to create an entirely referenced copy of Labs File Cache TOP (referenced to another copy of this node placed elsewhere). I'm trying to make this link relative in a `chs("../../"+opinput(".", 0)` type of way.
Generally, it was going well until I got to the multiparm block. (which serves for adding wedge attributes in this node)
I noticed that when we Ctrl+Alt+Shift+Drag that node, it will properly link the multiparm items, but this relation will now be fixed to this specific location, it won't work if we move the node. I couldn't find where it was actually getting that location from.
How can I link two multiparm blocks with expressions if I can't change their channel default value in the parameter interface?
How to channel reference a multiparm on an HDA node?
1609 4 1-
- alexmajewski
- 109 posts
- tamte
- 9376 posts
One way is to use opmultiparm [www.sidefx.com] hscript command
- vikus
- 247 posts
Not HScript but you can try the python solution if you like, hip below.
Note:
I saved the Labs File Cache TOP as a copy and modify it, added some parameters and code in the python module. This approach uses an absolute node reference. You can move the copy to any location as long as the reference stays in the same place. You can update the reference with sync button or revert.
Note:
- alexmajewski
- 109 posts
I'm super grateful to both of you. I ended up using the opmultiparm in a tricky way because it doesn't allow for any complex expressions in the parameters it replaces.
I created a Null with a multiparm copy. This way we can edit the default channel values of the multiparm. There I set my opinput trickery as default values, so it updates to whatever is connected to my tool.
Then, I used opmultiparm to hook my Labs File Cache to this Null which will always be right beside it. And that's it.
Thank you very much. Viklc, your code taught me a few things so it definitely didn't go in vain.
- vikus
- 247 posts
