Does anyone know where to change the command line path to houdini in window xp? The default for me came up as C:\Documents and Setting\
Weird. By I can't seem to find where I can change this path to what it should read.
windows command line path?
4931 3 1-
- bobster
- 88 posts
- goldfarb
- 3465 posts
- graphos1
- 53 posts
RMB (Right Mouse Button) click on the My Computer icon.
From the Context Menu that appears, select Properties.
From the System Properties dialog box (Tabbed Property Sheet), select the Advanced tab.
LMB (Left Mouse Button) click the Environment Variables button.
You can also access the same dialog from Start > Control Panel > System.
Additionally, open the command prompt and, on the command line, cd to the appropriate drive and from the resulting prompt, type ‘set’ (without quotes) to view the environment variables for your system.
At the prompt, type /? for help. Use ‘Help and Support’ from the Start button for more details on using the Command Shell and setting paths.
graphos1
graphos1
- bobster
- 88 posts
