Hello, I don't know what would be the right term so I'll try to explain what I'd like to do, it's similar this tutorial
https://www.youtube.com/watch?v=ChMOi34MKag [www.youtube.com]
Where spheres are attached to a moving surface, but they are static,
I'd like to make the spheres to move along the surface.
And I'd like to use different objects/geometry to move along surface.
Is there a name for this type of animation/effect?
And any tutorials?
Make objects/particles "dance"/move along a surface?
1530 3 1-
- VinnniPereiraa
- 3 posts
- animatrix_
- 5097 posts
This is very easy to do. Have particles move however you want and then project them back onto the surface using xyzdist VEX function [www.sidefx.com] so they can't leave the surface.
The forces and velocities should be small enough so they don't appear jumping across different parts of the geo, or you need to use a lot of substeps.
If you want even more predicable results, make sure to have your velocities tangent to the surface by removing the normal component.
- VinnniPereiraa
- 3 posts
animatrix_
I'd still have to animate the particles... But I can make it procedural, which is close to what I was looking for, I don't know how but I think I can figure that.
Alright! I'll check that function and make some tests!
- cncverkstad
- 173 posts
