Sink flip particles dymamically
1334 4 1-
- mzigaib
- 1032 posts
I am using FLIP SOP and a flip boundary SOP to source a sphere with a mask point attribute noise with values between 0-1 sourcing on the first frame, as I start the sim this mask attribute get stick to the particles and I want to remove particles with values bellow 0.5 at certain frame dynamically, how can I do that with this workflow?
- tamte
- 9417 posts
- mzigaib
- 1032 posts
Thanks for the feedback,
I tried with a pop kill but no success I will try with the pop wrangle, seems in order to make wholes on the fluid surface I think you need some kind of volume operation but I do not know how to do it inside the flip SOP, am I wrong?
Edited by mzigaib - Feb. 11, 2025 00:49:14
- tamte
- 9417 posts
mzigaibPOP Kill will not work directly, since POP Solver that's inside of FLIP Solver has Reap Particles unchecked, so it doesn't remove @dead particles
mzigaibduring the simulation you can just delete the particles as the surface is generated from them
however if you want to do it on the source before sourcing then yes, FLIP Solver SOP uses volume sources
Edited by tamte - Feb. 11, 2025 00:56:16
- mzigaib
- 1032 posts
