I'm looking for a way to add a "Copy Guide" option in the Guide Groom tool. I noticed that the guidegroomcore node has a tool parameter with options like Draw, Plant, Sculpt, etc.
Is there a way to modify this list to include a custom Copy Guide tool? Or is there a better approach to duplicating guides within the Guide Groom workflow?
Any suggestions would be greatly appreciated!
How to Add "Copy Guide" Tool in Guide Groom?
940 3 1-
- siddarthmehraajm
- 2 posts
- freshbaked
- 152 posts
Usually I just use the plant tool in single mode and plant a guide right next to an existing guide so it closely matches it's shape then you can use the move tool on the new guide and place it where ever. I think you can even select a guide first, then when you plant a new one it will only interpolate to the selected guide. I don't know if that helps, it's been a while since I had to groom anything.
- siddarthmehraajm
- 2 posts
- freshbaked
- 152 posts
Enable "rotate with skin"
https://www.sidefx.com/docs/houdini/nodes/sop/guidegroom.html [www.sidefx.com]
