VEX - Calculating perpendicular vector to given direction
   3071   18   2
Hey there,
I am trying to calculate the perpendicular vector to a dynamic direction in vex but so far I just cant get it to work. Cross product came to mind but then I would need two vectors to calculate the perpendicular, but in this case I just have one direction from pt0 to pt1.
Edited by Kareeem - Feb. 28, 2025 08:05:39
www.rehimi.de
There is an infinity of vectors perpendicular to your direction. Cross product is indeed what you need. If any perpendicular vector will do, just use any vector as the second argument of your cross product. If you need a specific one, try to figure out on which plane you want it to be and use the normal of that plane as your second cross product vector.
This [en.wikipedia.org] might be of help.
Edited by Tanto - Feb. 28, 2025 10:00:56
You can do it like this:
vector getPerpendicularVector ( vector v )
    vector vn = normalize ( v );
    vector vu = abs ( vn.x ) < abs ( vn.z ) ? { 1, 0, 0 } : { 0, 0, 1 };
    return normalize ( cross ( vn, vu ) );
This should also work
vector n = normalize(set(p.z, 0, -p.x));
addpoint(0, p + n);
animatrix_
Wow, this seems advanced. I am having trouble understanding even the first line. What is this syntax? A short version for something?
Thanks for taking the time though, much appreciated!
www.rehimi.de
vikus
addpoint(0, p + n);
This actually works, thanks! I needed to fix it up a bit though
vector n = normalize(set(@P.z, 0, -@P.x));
addpoint(0, @P + n);
I´ll try to figure out what you are doing here ... I mean I get what you are doing but how on earth would one think of that?
Edited by Kareeem - Feb. 28, 2025 10:27:05
www.rehimi.de
It normal of a 2D vector. Fliping the axis of P and negate one of them. Hope the image explains .
Works in 3D as well you can build stable rotaion on that.
vikus
It explains that I should have smoked less weed in school. Thanks that definitely makes more sense now!
www.rehimi.de
Kareeem
Glad to help.
Here is an older file with rotation, scale where I lern the stuff:
Vector_Normal.hiplc (141.3 KB)
vikus
Kareeem
Glad to help.
Great, I will check that out!
www.rehimi.de
Kareeem
you can also write the same thing as :
vector n = normalize( cross( @P, {0,-1,0} ) );
but once you expand the math of the cross product that's what's left
Edited by tamte - Feb. 28, 2025 12:12:16
tamte
Kareeem
Oh wow, i think I finally got it now. I thought for some reason that the two vectors I feed into the cross product need to be perpendicular to each other to beginn with and if they are not the result of the cross product would also not be perpendicular.
I think this image gave me that idea
www.rehimi.de
Tanto
So you were correct right from the start. I can use any vector as the 2nd argument. How cool is that cross function?!
Edited by Kareeem - Feb. 28, 2025 14:38:03
www.rehimi.de
Kareeem
animatrix_
It's ternary operator [en.m.wikipedia.org].
animatrix_
Hey thanks for clarifying! Although I did not know that term I was aware of the"short version" of the if statement.
But I am still not sure what you are doing in the first line ... Are you creating a custom function here?
Edited by Kareeem - March 1, 2025 02:40:13
www.rehimi.de
Kareeem
animatrix_
Yes.
animatrix_
I dissected this and wrote it down in vex code I can understand for a detail wrangle and without the custom function. Thank you for the inspiration. I still have a hard time understanding how you can come up with the math but I guess it again comes down to the basic knowledge Vicus posted here as well and experience.
// calc dir from start to end
vector start = point(0, "P", 0);
vector end = point(0, "P", 1);
vector dirn = normalize(end-start);
vector diru;
// calc math magic
if (abs(dirn.x) < abs(dirn.z)) {
    diru = {1,0,0};
else{
    diru = {0,0,1};
// export @
v@N = normalize(cross(dirn, diru));
Edited by Kareeem - March 1, 2025 07:57:49
www.rehimi.de
The abs line picks the axis that is least aligned with vn, ensuring the cross product produces a well-conditioned perpendicular vector with a stable magnitude.
If vn is already close to { 1, 0, 0 } (X-axis), then { 1, 0, 0 } is a bad choice for vu because the cross product would produce a very small (almost zero) vector, leading to numerical issues.
If vn is closer to { 0, 0, 1 } (Z-axis), then { 0, 0, 1 } is a bad choice for the same reason.
animatrix_
Nice, thanks for explaining it once again!
www.rehimi.de
