sekow
Jordi, you keeping me smiling in such dark days
thank you again for the effort. it is much appreciate.
Softimage to Houdini guides
219915 335 9- jordibares
- 655 posts
- cb
- 635 posts
jordibares
And another one… I am quite happy with this one in particular… hope you like it.
I would also like to ask Houdini experts to review if it is ok and if they see any drawback on the various techniques approached… I know a few but this is a never-ending concept.
https://www.dropbox.com/sh/y0ti6tyf7o3435u/thsQH1Kf2o [dropbox.com]
HoudiniGuides_GeneralConcepts_OrganisingScenes.pdf
Jordi, sir, you rock. And we should talk
Cristin
- Andi Farhall
- 115 posts
- RobW
- 147 posts
- jordibares
- 655 posts
Your comment means a lot Cristin, happy to help whenever you want and I am sure I can put together a bunch of top Softimage artists that surely would like to help too.
cbjordibares
Cristin
- Digipiction
- 166 posts
- scaron
- 6 posts
- alanf
- 4 posts
Thanks for the guides, Jordi! Can't wait to become a master wizard.
Would you mind continuously editing the first post with links to them as you create/update new ones so we don't have to scroll through multiple pages to find them all? Thank you.
By the way, if it helps anyone, I found a H9 hotkey cheatsheet:
http://www.sidefx.com/images/stories/blogs/houdini9_blog/h9_quick_ref_card.pdf [sidefx.com]
- rmagee
- 1183 posts
You can also find hotkeys on the back page of this doc:
http://www.sidefx.com/images/stories/getting_started/guide_introduction/hguide_00_introduction.pdf [sidefx.com]
The descriptions along the way also highlight important UI elements and hotkeys.
- jordibares
- 655 posts
The link is to a dropbox account so it is everything I have published, no need to tweak links… I am just reminding people where they are rather than updating it.
alanf
- jordibares
- 655 posts
I am on fire… ;-)
https://www.dropbox.com/sh/22l2sx82m75buxj/H-0buUQAUP [dropbox.com]
HoudiniGuides_GeneralConcepts_OrganisingMaterials.pdf
Edited by - 2014年5月6日 09:44:47
- anon_user_37409885
- 4189 posts
- malexander
- 5174 posts
Very nice Jordi!
Small correction - in the nodeflags pdf, the flag you've labelled as Template in the COP node is actually the Render flag. In COPs (and CHOPs) you can have multiple display flags, so the Render flag is used to define the output of subnets (and the COP to cook if a node path refers to the containing COP network, not a specific COP). It would have been a bit of a workflow issue to combine the render/display flags into a single flag button in COPs because of this.
- Netvudu
- 304 posts
Jordi, just two really minor corrections to the Organizing Scenes pdf. Actually it´s just a procedural modelling correction so you might overlook them as they´re not the main topic, but just in case:
- At the procedural approach to the table section, when you create the tabletop, you affirm “…the tabletop that has been created with a simple extrusion of the grid (not very good technique as there will be an opening on the bottom)”. That´s not correct. If you check the “Output Back” setting at the polyextrude node there will be no opening.
- Also you could simplify the process with one less node, just taking out the second transform after the leg (xform_freezeaxis), and adding to the center Y parameter of the box the expression “-ch(”sizey“)/2”, so the leg will always be centered just below the c-plane exactly in the same way you did with the transform…minus one node.
Of course, some people prefer to separate the transform from the primitive node “by design”, which I can understand.
Javier Meroño
FX TD.
FX TD.
- SimonWEC
Hey Jordi,
Great to find this stuff here. I've just finished a whole preliminary round of development for a project of my own in XSI only to learn… well we all know what's happened.
So I have all my fantastic set up scripts and guide rigs for my characters in XSI, where do I start in porting these over to Houdini…? Python's not a problem by the way and I am glad to see Houdini supports that as well…
All the best
//Simon
All the best
//Simon
- edward
- 7773 posts
jordibares
One more guide ready
HoudiniGuides_GeneralConcepts_ComparingInterfaces.pdf
Jordi, in Houdini, there's really sort of two animation worlds: keyframes and CHOPs. Do you think they're sort of mappable to XSI concepts like fcurves vs NLA?
- symek
- 1390 posts
jordibares
I am on fire… ;-)
Great guide so far, Jordi, I wish I had such thing leaving LW 10 years ago :shock:
One thing to note is that once you start placing materials inside an objects (which makes access scattered), Material Palette starts to be really handy. It jumps through the networks while selecting items, so it's a matter of keeping parameter pane opened to tweak any material in a scene whatever deep buried.
Also worth mentioning: Ctrl + click on an IPR viewer opens materials applied on the object under the cursor.
- jordibares
- 655 posts
- jordibares
- 655 posts
You may want to see what is there first as IMHO you want to embrace the package philosophy, be that Houdini, Modo, Maya…
If are in London we could talk to our Houdini experts here at Realise to see how to help you on the transition of tools to Houdini if you are open to release them to the community.
Is that a possibility? if not you are more than welcome still so don't hesitate to ping me.
cheers
cheers
SimonWEC
Hey Jordi,
All the best
//Simon
- jordibares
- 655 posts
Thanks, I wanted to showcase it as a different transformation for educational purposes.
But also, I am one of those that want default nodes being transformed as a second operation rather than not so substituting the input object bring predictable results.
One of the documents I will be preparing is to try to differentiate transformations by what they do and certain style options that surely are a personal bias but for me are important.
thanks a lot for the pointers!
Netvudu
