chops wrangle - access min/max value of a channel?
   8664   18   5
Dabbling with channel wrangles, can see this handy stuff in the info window (see attached image).
Is it possible to access that in a wrangle? I hoped chattr() would do it, but all my assumptions about what that attribute might be called aren't valid. Eg
int success=0;
float result;
result = chattr(0,'channel','min',C,-1,success);
if (success) {
  printf('%s',result);
} else {
  printf('fail');
I'm sure I could get to it with other chop nodes, but would be nice to just pull it in directly via vex.
This is an interesting one…I couldn't find a way to pull data with this function.
オンライン
Weeee first forum post! Here's my attempt at a solution, though there has to be a faster way.
float sample[];
for(float i = 1; i < L ; i++){
    float test = chinput(0, C, i);
    append(sample, test);
float max = max(sample);
float min = min(sample);
オンライン
What about using an Expression CHOP first to compute the min/max via the icmin()/icmax() hscript expression functions?
Hscript? Expression chop? Ew.
Yeah that'll work, but feels like some more vex chops functions would be handy.
+1 to more chops vex functions
Can I throw in the idea of some channel creation functions…? I'm probably going to try writing some of these in the next few days, so I'll be back with some stupid questions.
Henry Dean
In the short-term if you need them, you can always drop something like this into your vex include directory
then plonk #include <chop_custom.h> at the start of your wrangle
Edited by friedasparagus - 2017年4月18日 06:20:57
chop_custom.h (532 バイト)
Henry Dean
I'll need to add more vex helper functions for chop.( chinput_minmax being one of them ).
You need to be careful when doing loops in Channel wrangles because the code will be executed for each time sample and for each channel.
One way to get around that is to create an intermediate set of channels in a wrangle and make sure it has its first input unconnected and is setup in a non time dependent manner. This gives something similar to a detail wrangle in SOP, but with much more headaches. (It's the wave_compile_minmax node in the red group comment box).
Another way is to use the new per channel attributes that you can set/get with chsetattr/chattr. This gives you a single chain of nodes and you can store attribute on channels, but the Channel Wrangle doesn't yet support being executed only one time per channel when the node has multiple time samples.
chinput_minmax.hip (61.5 KB)
Ah sugar lumps! I was thinking that iterating over channels meant that it would only run a loop once for each channel…
Henry Dean
friedasparagus
It isn't clear. I think Over all Samples computes all the samples from the first channel, then moves on the next channel. It's the legacy iteration mode where you couldn't write to multiple channels at the same time.
Over all Channels, sets the time to the first sample, then iterates over all the channels. sets the time to the second sample, iterates over all the channels and so on.
Every Nth Channels is the same as Over all Channels, but it regroups multiple channels together.
as a side question, while talking about Channel VOP/Wrangle CHOP, this seems to be based on the old vopchop, is there a plan to make a CVEX version?
Or even something more customized that'd allow for binding(in/out) channels or channel groups by name/pattern? Like Volume VOP allows for volumes, that would be invaluable
CG Supervisor
Framestore, NY
chinputlimits() !!!
how did this not make it to the changelogs? (only just noticed it on build 605)
lovely new iteration methods too!
Thanks very much guys!
Henry Dean
Oups. My bad.. the changes were a direct response to this thread. I did update the documentation on the CHOP wrangle node.
I guessed as much I know things along these lines have been said before, but for thoughts in a forum thread barely a month old to actually make it into the software is just bloomin' great! Keep it up!
Henry Dean
@Guillaume, please, I have tried this new function chinputlimits().
- chinputlimits(0,0,…) iterates fine and gives me min/max
- chinputlimits(0,1,…) seems to evaluate just the first sample … not over all the range
Am I doing something wrong? I have attached my file.
minmax.hiplc (97.2 KB)
tamte
+1
ikoon
No you do it correctly, the vex function has a bug and I'll need to investigate.
and yes we do want to move to CVEX, but it isn't something that can happen overnight.
I'll probably start by adding CHOP lookup functions to CVEX. Currently, you need to use a Channel SOP to import CHOP data into SOP, even if you are using wrangles.
So if I use Guillaume's method for generating min/max as an attribute on a channel. How would I fetch that value from a Python node in the /obj context?
I am trying to find the min/max rotation range for each bone in a mocap skeleton.
So the CHOP channel attribute is stored within the hou.Track()?
Edited by Enivob - 2018年5月5日 10:51:05
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
