HOUDINI HDK tutorial
6048 8 6- amin khormaei
- 25 posts
- N-G
- 209 posts
- amin khormaei
- 25 posts
- alexwheezy
- 209 posts
- DmitriiP
- 16 posts
- N-G
- 209 posts
DmitriiPIt is showed in a simple example:
installCommand
https://www.sidefx.com/docs/hdk/expr_2command_8_c-example.html#a10 [www.sidefx.com]
amin khormaei
it's not good for beginners
It is easy if you read it from beginning and it would be hard if you suddenly jump at the middle of HDK.
This is not Houdini documentation responsibility to teach you how CMake works or how C++ compilers work.
There are many samples in HDK with comments which show you how to use development kit.
You should learn C++ deeply enough to work with HDK otherwise it would be really annoying to work with.
You can also use Inlinecpp module in Python:
https://www.sidefx.com/docs/houdini/hom/extendingwithcpp.html [www.sidefx.com]
- DmitriiP
- 16 posts
N-G
what is the “:” after the letter? why with “eeeee:” just breaking everything?
why in this example “1” not “1:”?
http://www.sidefx.com/docs/hdk/_f_s_2_f_s__background_8_c-example.html#a33 [www.sidefx.com]
and so on ….
this is not “really good” documentation, just simple description…
- animatrix_
- 4528 posts
You can also use the C++ Wrangle if you want zero setup time (almost zero on Windows):
- N-G
- 209 posts
DmitriiP
and so on ….
As documentation says:
If the letter is followed by a colon, the option is expected to have an argument (use two or three colons to indicate two or three arguments respectively).
As I said, you should read HDK documentation step by step otherwise you will lost!
More information about CMD commands can be found here:
https://www.sidefx.com/docs/hdk/_h_d_k__extend_c_m_d.html [www.sidefx.com]
Edited by N-G - 2020年3月5日 19:47:22
