Mapbox not loading terrain data
   7127   2   2
I used to be able to use Mapbox to download terrain data. Now it is not working for me. I am using Houdini Indie 17.5.173. I am pasting in API code from website, navigating to map location and pressing download. It waits for awhile but then nothing loads up. I waited for a long time to make sure my patience wasn't the issue! Any ideas?
space-G
it wont auto-frame after it imports
Same I get an error when I try to sample from the map (I go to the most zoomed in tile so it's not a data issue). - any idea why? Any help much appreciated. I'm on the latest build and have updated my plugins.
Right clicking on the node throws up this error :
Error
Invalid source /obj/geo1/mapbox1/optional_blur/terrain_layer1/foreach_end2
Error: Failure to cook template geometry..
This is what the console throws up in error :
File “opdef:/labs:op/mapbox?PythonModule”, line 195, in <lambda>
File “opdef:/labs:op/mapbox?PythonModule”, line 65, in on_button
File “opdef:/labs:op/mapbox?PythonModule”, line 146, in refresh
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.532\python27\lib\urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.532\python27\lib\urllib2.py”, line 435, in open
response = meth(req, response)
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.532\python27\lib\urllib2.py”, line 548, in http_response
‘http’, request, response, code, msg, hdrs)
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.532\python27\lib\urllib2.py”, line 473, in error
return self._call_chain(*args)
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.532\python27\lib\urllib2.py”, line 407, in _call_chain
result = func(*args)
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.532\python27\lib\urllib2.py”, line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 404: Not Found
Could not create OpenCL device of type (HOUDINI_OCL_DEVICETYPE): GPU on platform vendor (HOUDINI_OCL_VENDOR): Intel(R) Corporation. Falling back to built-in CPU OpenCL driver.
Edited by jamestmather - 2020年8月7日 10:26:37
