XPU tests (with sample scene)
33467 93 6- GCharb
- 250 posts
- EdganHomt
- 13 posts
- PaQ WaK
- 89 posts
- GCharb
- 250 posts
EdganHomtA biased render engine is not physiqualy accurate, it uses algorythms and tricks to approximate the physics of lights, making it faster, but innacurate, this is rendering 101.
You are using "biased" as if it meant something for you, have you done research on what is actually biased or you are just spouting it? I use both Houdini and Blender, and it's much better than using any of them alone.
As for blender, it is very limited, and everything Houdini does it does better than blender, I see no points in using both TBH.
One of the things that I never understood about the way blender work is why on Earth, in 2021, a DCC app would makes a primitive like a sphere parametric at creation time, but then as soon as you deselect it it becomes a static, non parametric object, makes no sense to me that they never fixed that, this is one of the reasons most pros wont even have a serious look at blender!
Edited by GCharb - 2021年11月5日 15:17:56
- GCharb
- 250 posts
PaQ WaKPretty amazing TBH, I am looking at moving to Linux as we speak, well worth the effort IMHO, especially since there is a Linux version for most of the tools that I use!
@GCharb, indeed the speed gain is insane Oo
Rhino Scene
Windows 10:
CPU : 12:08
XPU : 03:43
Linux (POP OS 21.04)
CPU : 04:59
XPU : 03:16
TR3970X / RTX2060 super
- 7802 posts
- GCharb
- 250 posts
- 7802 posts
GCharbjsmackA bug that would make Karma really slow under Windows, 2-3 times slower?
That looks like a bug. The difference between the XPU tests is more plausible.
Yes, a performance difference in that range is surely a bug. Differences due to kernel scheduling are generally not going to be orders of magnitude. There has been a bug in karma in the past that caused this large of performance difference when using certain texture formats that has since been fixed.
- GCharb
- 250 posts
jsmackI would love to hear what SideFX has to say on this, I have seen other apps run faster on Linux, but not such a difference, someone needs to make tests between 18.5 and 19 on Windows, to see if that's the case, and if you are right, it means that SideFX hasn't fixed a major bug in 9 days!
Edited by GCharb - 2021年11月5日 17:18:23
- Andy_23
- 918 posts
jsmackGCharbjsmackA bug that would make Karma really slow under Windows, 2-3 times slower?
Are there textures in the Rhino scene? I've converted textures to RATs and have not seen differences in render times using Windows. Maybe the bug returned?
- GCharb
- 250 posts
Andy_23No, only two simple MaterialX shaders that can easily be replaced with Principled shaders, but it seems to me that if 19's Karma was much slower than 18.5 under Windows, that users would have reported it on the forum after 9 days!
Edited by GCharb - 2021年11月5日 17:39:21
- GCharb
- 250 posts
This bothers me, so I modified the scene to use Vex shaders instead of MatrerialX shaders and rendered it in H19 in linux, I lowered the sample count to 256 to make it faster, since it's a CPU only test, I will re install Windows 10 Workstation and render the scene in both H18 and H19, to see if this is a Windows bug, or if indeed there is a huge render difference under Linux!
Linux H19 CPU render time: 8:18
Windows H18 CPU render time: 11:56
Windows H19 CPU render time: 26:49
I attached the VEX scene
Edited by GCharb - 2021年11月6日 11:25:00
- PaQ WaK
- 89 posts
Rhino Vex - TR3970X - CPU
Linux H18.5 : 02:27
Linux H19 : 01:38
Windows H18.5 : 02:47
Windows H19 : 05:53
Edit : On windows I do however have a bunch of compile error msg, and for some reason the bg color is back.
There is definitively something odd in H19 Windows.
Linux H18.5 : 02:27
Linux H19 : 01:38
Windows H19 : 05:53
Edited by PaQ WaK - 2021年11月6日 12:26:17
Gameloft
- GCharb
- 250 posts
PaQ WaKSame here, render time is more than twice the time as the one in H18 windows and Linux, so Linux isn't really faster, so back to Windows for me, less hassle!
Rhino Vex - TR3970X
Linux H19 CPU render time: 01:49
Windows H18 (18.5.672)CPU render time: 02:47
Windows H19 CPU render time: 05:48
As for the errors, I created the file in H19, there seems to be compatibility errors, I have redone the file in H18 and there is less errors in H19 now!
Edited by GCharb - 2021年11月6日 11:26:19
- habernir
- 86 posts
PaQ WaKin linux H18 what the render time?
Rhino Vex - TR3970X
- PaQ WaK
- 89 posts
- GCharb
- 250 posts
- chrism
- 2494 posts
- Sunteex
- 5 posts
- jarenas
- 146 posts
chrismThat's great to hear!
re: windows slower than linux
We're aware of what's causing the issue now and we're working on a solution.
This is unfortunate, as a great number of motion graphics freelancers and small studios, who may be evaluating H19 Karma right now for their workflows, will be doing so under Windows...and we're talking about 2x speed decrease because of this bug! In any case, I really appreciate the quick response from SideFX and all the very visible improvements and care put on Karma on H19!
Edited by jarenas - 2021年11月10日 09:55:00
