Is Flip Upresing a new feature available in H16? In the Whats New in H16 video and the live event a new technique of using lowres simulation as guide for upres flip simulation is shown. But I am not able to find anything related to this in H16 or any documentation related to this. How is it done?
Thanks.
Houdini 16 - Flip Fluid Upresing ?
22803 19 9-
- ljpramod@live.com
- patar
- 280 posts
- Skybar
- 166 posts
- vanyfilatov
- 16 posts
- Skybar
- 166 posts
- rgoldade
- 73 posts
Hi everyone,
We have a masterclass coming out soon that will explain how to set up a re-sim of a river simulation. However, I will do my best to explain the workflow here and answer any questions that come up.
The re-sim idea comes from the addition of the “Boundary Layer” in the FlipSolver node. With the Boundary Layer, we can maintain a surface and velocity in a thin layer around the volume limits of the simulation based on SOP volumes that we link in. This is valuable because we can now prescribe in-flow and out-flow velocities at the volume limits, whereas before the limits were closed (i.e. zero velocity) or open (i.e. any outflow velocity). By setting the velocity to exactly match our linked velocity volume, we have much more control over our simulation. The surface volume controls how the geometry is maintained in the boundary layer strip. Any voxels below our surface will be reseeded with particles and any voxels above our surface will have particles removed. This allows us to maintain fluid volume in the simulation when we want fluid flowing into the simulation through one region and out through another. For this reason, the Boundary Layer option is used heavily in the Oceans toolset.
For rivers, we need to bake out our low-res simulation first. We then load the baked geometry (surface and velocity) in to our up-res simulation through a File SOP and wire the surface and velocity into the Boundary Layer. In the example from the launch video, the up-res FlipSolver's volume limits were adjusted to focus on a small section of the river to be up-res'd. We also modified the scene by adding a collision object. Finally, we need to seed new particles into the first frame. In the same Geometry node as the File Sop, we used Points from Volume to seed particles into the low-res surface (only within the volume limits of the new simulation) and sampled the velocity from the baked velocity to assign to the particles. Theses particles used the new, high res particle separation. We then wired these particles into the FlipObject's intial data. This allows us to start the simulation with right lo-res velocity.
It is also possible to drive the up-res with GAS Guiding Volume (which is used primarily for the Guided Ocean Layer). But BUYER BEWARE we found that turbulence tends to form at the seam between the guiding volume and the free fluid volume. Because of this, we do not currently endorse this approach for doing an up-res, but we are researching how to solve this in a future version.
If you want to try anyway, GAS Guiding Volume is similar in spirit to the Boundary Layer but with arbitrary volumes. The surface of the guiding volume will force the fluid simulation to match the guiding velocity, much like how the Boundary Layer forces the fluid simulation to match its velocity at the volume limits. Therefore, you will need to modify the low-res baked surface to only be “plugs” on either end of the simulation before you link it to the guiding volume. Finally, it's essential to make the appropriate modifications to the “Solver” tab in the FlipSolver so the guiding volume is visible to the solver (see http://www.sidefx.com/docs/houdini/nodes/dop/gasguidingvolume [sidefx.com] for instructions).
I hope this helps!
Ryan
I hope this helps!
Ryan
Edited by rgoldade - 2017年3月1日 11:12:32
- patar
- 280 posts
- rgoldade
- 73 posts
- Skybar
- 166 posts
- rgoldade
- 73 posts
I've attached the .hip files used for the river re-sim. The boundary_layer_river.hip file is the “low res” river, using the boundary layer to maintain the flow rate and water level of the river. The resim_river.hip file loads in the geometry from the boundary layer example and re-sims at a higher resolution, with a collision object and only simulated in a small region of the river.
I've attached an example of using the guiding volume approach instead of the boundary layer. This is for those who are curious about the setup. Again buyer beware here. The tool was designed for use with Oceans in H16 and has the potential to be generalized for many other features. However, we have noticed some instability at the seams so we don't currently endorse using it for this purpose.
Enjoy!
Ryan
Enjoy!
Ryan
Edited by rgoldade - 2017年3月1日 17:51:15
- Skybar
- 166 posts
- Skybar
- 166 posts
I have one question. The thing I'm working on needs to be pretty quick, so I upped the initial velocity to 10, both for the boundary vel and initial vel on the flipobject. However, doing this the top of the river starts eating itself forward and I get a gap where it won't seed any particles (because the surface isn't there anymore?). Eventually the velocities at the top there goes really crazy and kinda blows up in a big wave.
In the boundary_layer_river.hip, set your initial velocities to 30 or higher and you'll see what I mean.
Why does this happen? Is it a case of needing substeps or something else?
edit: It works a lot better if I add a source to fill in that gap, and the velocities there no longer blows up as well. But this seems a bit counter-intuitive seeing as the setup is “source-less”. Could the problem be because the particles is being seeded and then advected directly afterwards? As opposed to sourcing post-solve which seems to “solve” it.
Edited by Skybar - 2017年3月2日 11:36:45
- rgoldade
- 73 posts
That could definitely cause a problem if your river is flowing fast enough to escape the boundary layer in each frame. The boundary layer acts as a source at the reseed step. This happens before the advection step so in your example it makes sense that using a source shows an improvement.
For slower moving rivers, the source might seed into non-empty voxels and create more particles than necessary, which will then be deleted in the next reseed step. The boundary layer doesn't over populate voxels, making it more efficient, but is susceptible to fast moving simulations.
- patar
- 280 posts
- rgoldade
- 73 posts
There's no real satisfying solution for upressing something like a droplet. The suction fluid tool might help direct the high res simulation to match the low res. However it tends to behave like an elastic band if the hi res deviates too much from the low res. Adding drag to match the low res velocity might also help. Both of these approaches can get the high res closer to matching the low res but it will require a lot of parameter tuning. Because of this, we only encourage upressing using container boundaries.
- MorpheauxOneiroi
Guided bend river is hard to setup on daily basis, with that box setups everywhere, it didn't work in my case, i used like 9 bend nodes to make the box bend on my river, but later part on generating velocity, the bends distorted the particles mucb further, dont know why still Searching for solutions, i think is due to the volume and match size stuffs which I don't know about, anyone with solution?
- rgoldade
- 73 posts
- Patrick Goski
I'm digging up this old thread, since I was going through the masterclass and ran into a few issues.
The biggest one is when loading in the baked low resolution simulation.
The nodegraph for "cropping" the surface and velocity volume doesn't seem to function.
From what I can tell the fluid compress node is turning the volumes into VDBs, but then the Volume ReSize nodes only function on real volumes. I can step around this by converting the VDBs to volumes, but that doesn't seem to be needed in the demonstration.
I checked the supplied files, but am not seeing where the issues happen.
The next thing would be that when I use the resulting particle field in the DOP network as my source, it is not sourcing the velocities that I transferred to the source points.
I have tried to disable "Initialize velocities" but then I get the big waves at the front of the boundry.
In the provided file, it seems like "Initialize velocities" is enabled which would override the velocity that we copied over.
I guess I'm kind of confused by these things, as they seem conflicting, or that some functionality has changed.
Would be wonderful to have some guidance on this to know if I am just chasing issues that aren't issues, or are bugs.
- 9447 posts
you can also have a look at newer workflows which are simpler to use
https://www.sidefx.com/docs/houdini/fluid/sopupressing.html [www.sidefx.com]
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- Hamilton Meathouse
- 211 posts
tamte
Just a note on this tutorial, in order for upres to work and maintain the general shape of the low res sim, you need to change the Boundary Condition in the Hi-Res solver to 'Velocity Driven' - see attached pic.
