Is there an interactive way to edit pscale on a curve?
   2694   10   3
I'm using Sweep SOP to create a simple tube-like shape from a curve:
In the above image I use a noise pscale. But what I actually want is to edit the pscale manually. Is it possible to be done in Curve SOP or Edit SOP?
I know I can use an extra Attribute Wrangle with a ramp parameter, but I feel that's quite unintuitive. Especially when the curve is quite long and complex, it's hard to tell which part of the ramp is which part of the curve.
Screenshot 2025-02-21 132223.jpg (122.7 KB)
What if you plug in a Rig Pose SOP before the sweep?
Here is a simple approach far from perfect but a starting point:
Interface to tweak single attr float in the viewport? [www.sidefx.com]
freshbaked
I guess it's one way to do it... but still rather cumbersome. Rig Pose only reads/writes transform, not up/tangent/orient etc, so one needs to convert the output of Curve SOP to something that Rig Pose recognizes. And if the later node doesn't understand transform(for example, PolyExtrude only recognizes thickness), one has to convert it again.
Edit: for future reference, it's not that cumbersome. Just "3@transform = qconvert(p@orient);" Still one more node though.
vikus
This seems to be a more general solution. I'll take a look!
Edited by raincole - 2025年2月21日 07:12:38
raincole
Just uploaded a new file example with data change and sweep.
I would just be using a ramp to be honest. As far as "knowing which bit of the ramp is controlling what
bit of your noodle, you can just have curveu driving a color ramp. Then it's easy to see which bit is aligned
visually.
lewis_T
visually.
For one single curve maybe. But if you have multiple curves drawn in one single Curve SOP, using ramp(s!) to control pscale is abysmal UX...
What about an attribute paint?
CYTE
CYTE beat me to it - was going to suggest the same. You'll need to tweak the brush settings a little, but it's easy and it works.
Edited by Mike_A - 2025年3月10日 15:45:26
Rigpose seems to work as well.
Edited by toonafish - 2025年3月11日 17:46:21
rigpose_pscale_sweep.mp4 (2.6 MB)
raincole
lewis_T
visually.
Your screen grab showed one curve.
