I've been pondering whether I'm hitting the age where things get a bit too complicated, or if rigging in Houdini is genuinely more complex compared to other programs.
A bit of background: I've been in animation for over 25 years. I started rigging in XSI, then moved on to Maya. Nothing too fancy, but I could handle about 90% of my character rigging needs at a generalist level for freelance projects.
Recently, I've been casually exploring Houdini for both rigging and animation. My brain starts hurting with all the nodes and everything—it feels confusing. I'd love to hear from others who have switched from different programs to start rigging in Houdini.
Even the idea of hiring proper riggers for Houdini seems challenging especially for APEX being still fresh, and I thought it can't be that complex. I should be able to reach the level of rigging in Maya, for example, to create basic character rigs with legs, spine, arms, head, IK/FK, basic facial shapes, and controls. Am I approaching this from the wrong angle?
In short, I'm eager to hear about others' experiences diving into APEX and rigging, particularly from an artistic perspective rather than a purely technical one.
Blender on the other side seems with plenty of seemingly good addons for rigging according to friends who've switched. While I like Houdini and initially moved to shading, lighting, and rendering (I'm primarily a character animator), I now want to expand into rigging and animation. Sometimes, it feels overwhelming—age, lack of free time, and exhaustion. What are others' experiences?
Thanks for sharing your insights and venting! 😊
APEX rigging insight
12091 21 5-
- Mirko Jankovic
- 292 posts
- オンライン
- ASquirrel
- 341 posts
Ima throw my 2 cent here.
I've been rigging as a hobbyist in maya for a few year, I can tell this software kinda babysit you when it come to rigging, you put parent constraint, ik, just by selecting your bones and hitting the tools you need.
In my opinion, this don't really teach you rigging, it a high level of rigging, but you don't really know what really happen under the hood, what kind of math is happening ? trying to look at your rig in the node editor just pull a pile of spaghetti that impossible to untangle, and add to that that you have a 'hierarchy' of node in the outliner, thing are not clear, constraint override bone position, controller, bone and logic are split into chunk of mess sprinkled with ton of transform node in between.
sure you may end up sorta knowing what you do, create python script to automate you rigging, end up tools that have been developed for decade like advanced skeleton, with their own tangled messy code that near impossible to decipher.
here come kinefx and apex : bone are point with a name and a transform attribute, hierarchy is build using primitive, your skeleton is just a flat list of point that you can manage the way you wish. apex look like a purified node editor, with a clear view of every transformation that happen in your rig.
You as the rigger, manipulate the raw transformation matrix in a meaningfull way, you understand what you're doing, you know what your rig is doing, you connect your node because you want to achieve a specific behavior : your fk ctrl are just a chain of parent xform passed one after another, use these same xform to build yourself an interpolation curve, sample it as you see fit, and you got yourself a spine !
all the graph of a rig can be read from left to right : no bullshit cyclic connection, once layouted automatically each column become a 'step' : you clearly see what node depend of what step, first the root, then the pelvis, then the leg and the spine, until you reach the tip of the finger.
I've learned more about rigging in these last few month than I ever did in the last 7 year in maya. matrix transformation are less and less of a secret to me !
put that in addition to the fact you don't need to put a single line of python code to build a rig, and that apex is naturally designed to build 'rig builder', you end up spending your time thinking 'how will that rig be built' rather than 'how to build that rig'.
The Autorig component system is amazing, every little bit of your rig now become a little module that you can then reuse into bigger one, the potential for sharing, updating, improving without coding is a new shift in how you build your rigging tool.
there so much more I love about kinefx and apex, it a powerfull framework and there so much to discover that even the dev at sidefx probably didn't think of !
I have so much more fun rigging from absolute scratch in houdini than using those blackboxed tool from maya.
the simple fact you have access to the entire library of sop node also allow for absolutely new way of rigging that could never be dreamed of in any other dcc ever !
it true that using apex today can be very frustrating tho, it in it early phase, and little tool to help the user exist, but if you go beyong what currently availlable and think of all the potential, this is a little price to pay for a futur that look promising.
hope that wasn't too much of a nightmare to read
Edited by ASquirrel - 2024年1月10日 19:34:17
Head of Pipeline @ LightVFX
- kodra
- 373 posts
I've posted a lot of criticism about APEX and I definitely won't recommend using it on production.
But to your specific question:
Chicken/Lucha examples have IK/FK switch, 4-point spline spine and some facial controls (with bones, not blendshapes). At APEX's current state, I don't think there are much simpler ways to do this than how they did them in the example files. If you feel the example files are too complicated then yes APEX is too complicated.
I built my own autorig components for Ik/FK switch, forearm twist, reverse foot and blendshape driver and spine control in Python. It's about 1500 lines of code so far. I'm not saying my code can't be simplified further, but that's about what you need to build "basic" rig in APEX now.
The silver lining is that you can actually copy/paste rig components from Chicken/Lucha examples, but you still need to take time to read them carefully to know what kind of input they expect.
The first thing you should decide is how important "proceduralism" is to your workflow. APEX is very clearly built with proceduralism in mind: you'll be modifying the graphs with other graphs or code most of the time, and only manually edit graphs for prototyping/debugging purpose.
You can do this in Blender, too, but it won't be much easier than doing it in APEX. Blender has more high level constraints than APEX, sure. But first of all it's all manipulated with Python so if you prefer nodes than code Blender can't help you. If you only need basic stuff, yes you can use addons like Rigify or Autorig. However any custom logic still need to be done in Python if you want to do them procedurally.
Secondly, even if you prefer code like I do, Blender doesn't have something like APEX network editor where you can view the dependencies between nodes, which makes debugging rig much more difficult. I've been using Blender for years, but can I tell which constrain is evaluated first with 100% certainty? No. With APEX you have 100% certainty. You don't just kinda get it, you know it.
And last, Blender has its high-level constraints, and they're generally quite fast. However if you need a very unusual rig that can't be expressed with these constraints, you're out of luck. Sometimes you can do something with these constraints, but it requires a lot of intermediate bones. In APEX you might need a lot of nodes to do something specific, but at least you can organize them into a subgraph and call it a day.
However, if you just want to rig manually, Blender will be much faster than APEX. Anything will be much faster than manually editing your final rig graph in APEX.
There is not artistic perspective to be discussed in the current APEX. It's a very technical, low level stuff. The artistic part is the same as Maya or Blender.
My only suggestion is to wait for H20.5, unless your goal is to learn the logic behind rigging. By "logic" I'm not talking about "knowing when to use IK", more like "implement a swing/twist decomposition with quaternions". If that's not the stuff you're willing to deal with than APEX is no good for you at this point.
Mirko Jankovic
Edited by kodra - 2024年1月10日 23:28:33
- Mirko Jankovic
- 292 posts
- オンライン
I understand completely. It seems to me that the current APEX is at such a low level that it provides all the necessary controls, which is great for riggers
A couple of years ago, I would have definitely jumped into those tools again, for sure. However, now that I'm more focused on other aspects, I only need a bit of rigging for support. What I, and I'm sure many others actually need, are tools created by these low-level APEX nodes.
Essentially, something like mgear for Houdini, as an example. Let me set up guides for legs, fingers, and other elements, and build everything in the background. I don't want to manually create each bone, each FK/IK switch, and so on
Given that APEX is still relatively new, it's natural that it needs to first cater to the needs of riggers. Then, hopefully, riggers will develop tools for the rest of us. I'm confident that there are others who would be willing to pay for such tools, similar to how I'm paying for animbot for Maya, for example.
While most of these tools can be created by users themselves, it would take days, even months... Instead, I'd prefer to pay for a yearly subscription, use the tool, and focus on my primary work.
Does that make sense? It seems to me that the current APEX is precisely what riggers require, and with time, the rest of us may have access to tools created by riggers for animators.
Looking at it from a similar perspective, why do we need to create a box in the Houdini shelf when you can go into nodes and meticulously model your own box, constructing the entire network from scratch, vertex by vertex?
Thank you for your insights! It's still valuable to delve into these low-level aspects, of course, but not to the extent that I would want to build everything entirely from vertices
This master lass shows exactly what I mean.
Go for it riggers, but anyone else that just wanna simple rig tool should stay away from it
https://www.youtube.com/watch?v=-0KbPtoP5MU&ab_channel=Houdini [www.youtube.com]
Edited by Mirko Jankovic - 2024年1月15日 09:24:43
- 9606 posts
Mirko JankovicNo, it doesn't
Current APEX is beta, it's a proof of concept
It provides some control, some nodes, some workflows
But it's missing a lot of nodes, even low level ones, lots of UX to be productive and a lots of workflows
It needs to mature, whether for riggers or anyone, but it's definitely a great showcase of possible potential
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- ASquirrel
- 341 posts
even tho some node are missing (I needed a euler to quaternion and other similar function) the RunVex allow to pretty much do anything, so the limit is one's own skill I guess ?
I do know there is a performance overhead to using it, but until apex mature, it allow to virtually do any rig ever.
Edited by ASquirrel - 2024年1月15日 14:57:31
- 9606 posts
JacquesfI'd consider it a workaround that should not be necessary in a robust environment
On top of that yes, it's been said invoking vex in apex has a performance hit
But most importantly vex doesn't support all the apex types so its really only a workaround for math needs or processing geo, which can of course help a lot
But also at the risk of repeating myself, there is a lot of needs in rigging that the current apex architecture doesn't seem to easily allow for yet or workflows that are not yet in place, like lightweight history dependent constraints or interaction only constraints, etc...
So even vex wouldn't help to solve that as it's more about being able to selectively access runtime evaluated time sampled values, having smart internal caching system, or apex graphs invoked just to process interaction input but not be part of the runtime rig logic
Anyway, from my point of view there is a lot of room for it to mature even for rigging as there's a difference between just being able to do something and actually having a robust toolset that doesn't make it feel like you are doing a lot of workarounds or compromises
Edited by tamte - 2024年1月15日 17:34:00
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- anon_user_09389530
- 205 posts
Just my two cents: I’ve seen many people in production solve problems using only VEX or Python nodes. While this approach is great and flexible, debugging—especially for others—becomes much easier when generic nodes are used. Everyone knows how they work.
Edited by anon_user_09389530 - 2024年5月19日 11:16:50
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
- Jorge Ivanovich2
- 14 posts
- noc2
- 33 posts
tamte
Mr. Slancik hit the nail on the head!!...
I can see why and how Apex was conceived; it came out of the basic necessity of overcoming the performance/effective usability issues of Kinefx based rigs where kinefx rigs are not as responsive as one would expect. And there is also the basic paradigm redirection where the rigs should be easily understood and manipulated by professional animators without having to get into any node centric adjustment whatsoever.
At this current stage, it is almost completely not production-viable at all imho. Like Mr. Slancik put it, it is a proof of concept that needs to mature, and quite a lot as it seems...
Edited by noc2 - 2024年8月3日 17:44:37
- CV
- 64 posts
- Mirko Jankovic
- 292 posts
- オンライン
For me honestly it is a big step forward BUT I'm personally missing some details from full rigging process like from scratch start on kineFX skelelton, taging and then on to both autorig and the rest. Somehwo I fill in with misc tutorials here and there but still have these holes of information that are stopping for fully embracing it.
So I hope some nice tutorial with update for H21 and complete process will appear or even detailed course that would start from rigging ball with two legs up to human and other characters. Something that will focus on artistic side and not ve and scripts and things
But it is big step forward for sure.
Lack of free time to focus on learning does affect as well so others probably are far more successful
- maxmax003
- 20 posts
I think one thing that makes houdini feel harder to learn is that is harder to understand how nodes should be sequenced to work, I know this might sound dumb for people using houdini since the beggining, but like in maya, for rigging, the menus for joints, constrains, skinning, etc, are kind of in a sequence, they also are all grouped so you kind of go exploring a bit and following the interafe. In houdini all the nodes are in your face, you hit tab and node galore!, lol, so you have to know what you are looking for before hand, in that regard it feels like learning blender, there is a hotkey for everything, but no way to find it(it was worst before), so who would guess you need to pack a character before using it without watching a tutorial or examples, and I feel that kind of black boxes the rig, in maya you have all in there all the time, I know the apex graph etc... but that goes to the other side, where you could also in maya use the hypergraph(a long time ago) to help understand what your rig is doing. Also looking into the docs, you could look for a node, but it doesn't says what kind of nodes it needs before to make it work, they are like you need a string(in other words a geo path).... I feel the docs are too technical sometimes. And to be honest I wish I had started my 3d journy with houdini, now that I'm older I feel I have to read everything twice and I think only half makes sence, watching tutorials makes me sleepy, etc...old guy stuff.
- kevinthebright
- 225 posts
Mirko Jankovic
Same. I'm one of a subset of Houdini users that has never touched Maya. I like KineFx so APEX made me want to dive into rigging but sorting out the language / UI of the Apex Autorig Components has me stumped. Diving into the APEX graph helps but yeah, painful.
- Mirko Jankovic
- 292 posts
- オンライン
Another problem and piece of puzzle is that tutorials from couple months ago are not working any more.. there are changes made in APEX nodes and just get stuck with non working part and can't continue. Someone with in-depth knowledge that is fin, can probably work around the issue. For regular animator joe.. not so easy
APEX is still young and it is for riggers. But there is big population of people that don't wanna or don't care about being in-depth rigger. Just need wokring rig and move on to animation something that solves 80-90% of rigging needs. Like mgear in maya or those rigging addons in Blender.
For more complex rigging needs can always try to hire someone, but for most of the needs something simple like those would be more then enough. Saving time and money and allowing more people jump into animation instead of chasing unknown rigging nodes.
- kevinthebright
- 225 posts
maxmax003
They could help this by requiring an image of a basic node layout in every help doc. They have it in a few, like for each loops, but they are rare. Getting to a basic node graph layouts is why there are so many Houdini tutorials I think. I remember this from way back when learning the lattice node, magnet nodes, etc.
- Fraenk
- 31 posts
- オンライン
I'm also working as an animator/TD and currently switching from Maya to Houdini. You are right. Apex is not easy but definitely worthy as it is for all Houdini-stuff where the first couple of steps are pretty hard. The Apex-framework in general is really amazing. You can do stuff that isn't possible in any other DCC or just with a lot of extra work.
1. this seems basic stuff but on a simple apex-transform you have 2 extra inputs for "local" and "restlocal" that can be used during runtime. The local matrix for example can be used for procedural transforms (springs etc) but you can still use trs-inputs for animating on top (that is huge!) Also this restlocal can be set during runtime which is a pure pain in maya.
2. you can change the whole rig-graph on runtime! this was a big "aha!"-moment. what you can do with it is to change the specific parts on the rig while being in animate-state. try that in maya. what is it good for? well ... check out the worm-rig which is more or less a stretchy-spline setup. in a nutshell this example shows that the underlaying spline that controls the rig can be resampled based on the amount of controls the animator is choosing. also the ctrls-position will be updated. it's working with python-callbacks which are also a big pain in maya.
3. to get the whole benefits you must be able to code your snippets rather than sticking them together in the graph. but i'm used to do my prototypes in the rig-graph first (which is visually intuitiv) and if it works i'm translating the prototype to code. for this it took be me a bit to find out the difference between the rig-graph and the component-graph. but since you are there you can use the full Houdini-proceduralism. you can write your own apex-methods and store them so you can use them over and over again (in the rig-graph-context also as subnet-nodes if needed) You can use the inbuild-ui-parameters like ramps and stuff without the need of writing complicated qt-windows or something like in maya.
4.There are additional more kinefx-related things that are super cool like adding new geometry to an already weighted geo or replacing parts of a skinned geometry with no problem. Changing vertex-order several times? Easy.
De-attaching geometry for individual weighting and combining or copying them back? Not so hard.
Where maya has just one crappy weight-painting-tool since years nodody uses, Houdini comes with more than a handful of completely different weight-algorithms and the weight-painting tool is the best i've ever seen and used.
5. vibe-coding. i'm using claude a lot for vex stuff since months and claude is pretty good (but you need a solid linear algebra understanding if something doesn't work in the first place). for apex i'm either provide existing code i already wrote or the apex-api directly to feed into claude and asking then for assistance. this works pretty well!
So i personally feel that there is no simple yes/no-switching-to-Houdini-answer cos it highly depends on your will to learn stuff that has been automated in other DCC's and so on. but this framework is amazing and i already took this to production 5 times and i never regret it (both in animation and rigging). Those were simple chars tbh but each new one got more and more complex and i really hope SideFX will push this framework even further.
But yes ... since maya is now 25years+ ahead there are of course tons of free auto-rigger-tools, tutorials and modules you can grab on the internet. I started as TD and was able to build rigs without any knowledge of matrices and stuff. But on the same side and without "body-shaming" maya ... it's old, it's slow, it's buggy and Autodesk does nothing to change that which i personally really despise since years.
Good luck!
Good luck!
Edited by Fraenk - 2026年2月27日 06:21:50
- Mirko Jankovic
- 292 posts
- オンライン
No one is denying shear power of APEX.
But now us normal animators that simply don't wanna go too deep into rigging due to various reasons (learning it AGAIN after a bit of maya and softimage before now this again)...
Time for new generation now to use hat power and create something that others can use
And happily pay for those tools just give us tools that use all that power and put it in control.
Makes sense?
In a nutshell would be amazing to have mgear for Houdini based on APEX
Or like blenders rigify.. etc... Got the image
Makes sense?
- 9606 posts
Mirko JankovicWhile I haven't used those, most of rigging solutions are very cumbersome especially for tweaking the rigs etc
However the best solution for modular rigging I've ever used is CAT for 3ds MAX, nothing ever remotely come close and this was about 22y ago
- Powerful modules for spine, arm, leg, tail, wing, etc, all parametric, and editable at any time during production
- Procedural walk cycle, with full control over every element, walk on paths, terrains, editable footsteps, stride, leg phases, ...
- ephemeral rig controls, drag hand or torso ets as if it was IK even in FK mode or vice versa, ...
My dream is to have something like this in Houdini, would be ok with APEX as back end, but UX wise that was really the best a d most easy to use and flexible character rigging solution and likely still is
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- Mirko Jankovic
- 292 posts
- オンライン
Take a look at this intro:
https://www.youtube.com/watch?v=yxVpooIDQ-g [www.youtube.com]
Then take a look at any Unreal rigging tutorial — and that right there is why Houdini rigging and animation will stay stuck with a low adoption rate.
Everything shown for APEX so far is aimed at hardcore TDs, while the largest group out there — animators and artists who just need fast rigging tools to get to actual animation — are left completely out in the cold.
After testing Unreal and Cascadeur alongside other 3D apps for rigging and animation, I genuinely cannot see a single reason to choose Houdini for rigging over the alternatives. Animation-wise there are a couple of interesting things, but you can't even get to a proper animation project without working rigs, so...
Am I the only one finding APEX way too complex and out of reach for animators and artists, focused entirely on hardcore riggers?
With Houdini I'd expect it to be the first to have some proper procedural, artist-friendly tooling that gets people to a working rig fast. That's literally what Houdini is supposed to be good at.
