So I built a custom asset manager panel based on the tutorials by Varomix and have noticed that houdini 16.0 doesn't seem to understand when I bring the panel into focus. This results in me being unable to use hotkeys to paste, copy, or cut text in the QLineEdit fields, although surprisingly command-Z still works for undoing changes. Instead, houdini tends to paste any relevant information in my clipboard into the last non-python window I had active.
Any ideas how to fix this? For now I am stuck using the right-click context menu to do these operations.
Copy/Paste Hotkeys Not Working in Python Panel
2944 4 2-
- NFX
- 184 posts
- NFX
- 184 posts
So I am still trying to figure out this issue. I've tried forcing the QLineEdit to be in focus, but Houdini is still intercepting my keyboard's clipboard commands.
Below is the simple program I am running. Basically it is just a text field that I expect to be able to copy and paste from. Any idea what I am doing wrong?
from PySide2 import QtCore, QtWidgets
from PySide2 import QtCore, QtWidgets class TextField(QtWidgets.QLineEdit): def __init__(self, parent): super(TextField, self).__init__(parent) self.setPlaceholderText('Hello World') self.setFocusPolicy(QtCore.Qt.StrongFocus) class Example(QtWidgets.QWidget): def __init__(self): super(Example, self).__init__() tf = TextField(self) tf.move(30, 65) tf.setFocus()
Edited by NFX - 2018年1月22日 15:08:50
- rvinluan
- 1495 posts
- NFX
- 184 posts
- NFX
- 184 posts
It's been a few years since this was posted, but I recently ran into this issue again. Along with the context menu solution, I found this to work as well:
from PySide2 import QtWidgets, QtCore, QtGui class CopyableTextEdit(QtWidgets.QTextEdit): def keyPressEvent(self, event): if event.matches(QtGui.QKeySequence.Copy): QtWidgets.QApplication.clipboard().setText(self.textCursor().selectedText()) return if event.matches(QtGui.QKeySequence.Paste): self.insertPlainText(QtWidgets.QApplication.clipboard().text()) return if event.matches(QtGui.QKeySequence.Cut): clip = self.textCursor().selectedText() QtWidgets.QApplication.clipboard().setText(clip) self.textCursor().removeSelectedText() return super(CopyableTextEdit, self).keyPressEvent(event) import hou hou.session.text_widget = CopyableTextEdit(parent=hou.qt.mainWindow()) hou.session.text_widget.setWindowFlags(QtCore.Qt.Window) hou.session.text_widget.show() hou.session.text_widget.setPlainText('Hello World!')
