Getting wire names from a COP cable
   382   4   1
I connect the "cable of all outputs" of a node to the Contact Sheet COP. So far so good.
Now I want to add labels to the contact sheet, because it is difficult to visually say which image is which output.
If I could get the name of the wire (or layer, if that is how it works) in an expression, I could use it in a Font COP and make a new contact sheet to compose with the other.
I was hoping to get the name of a layer by reading the "name" primitive attribute, as this is what I am seeing in the Geometry Spreadsheet, but I tried this and many similar ideas to no avail. Does anyone know a trick that will get the job done?
Edited by cemg - 2026年11月22日 17:46:33
Answering my own question, some TOP plus ROP magic can do it. But if you have a simple solution staying in COPs I would love to hear it.
you can do it using Block even though it has some gotchas and hoops you have to jump through to make it work and even then it may still complain, but seems to work
Screenshot 2026-11-23 114037.png (364.3 KB)
ts_cop_font_using_cable_layer_name.hipnc (108.2 KB)
CG Supervisor
Framestore, NY
It is crazy that this works I don't understand how the Cable Merge at the end can just function like that, without matching names. Thanks for the solution.
cemg
Its still matching by name, COPs is full of weird quirks at this point that are discoverable only by accident, like that a single layer cable doesn't appear to be a cable anymore and yet still has a name even though node info doesnt show it
CG Supervisor
Framestore, NY
