Hi Folks,
I'm a newbie with Linux and Just installed Houdini 6, sourced the environment, all OK (seemingly) but when i try to run anything Iget this msg:
houdini: relocation error: /usr/hfs6/dsolib/libHoudiniUT.so: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
:roll: Can somebody pleeeeaze help, I'm running RedHat 9
thanks
lf
Houdini for Linux Dummies
9927 8 2-
- tallkien
- 225 posts
- lisux
- 581 posts
- stevenong
- 1634 posts
Hi there,
Yes, lisux is correct to say RH9 is not supported however you can still get Houdini to work. Please try the following thread:
http://www.sidefx.com/forum/viewtopic.php?t=1124 [sidefx.com]
Cheers!
steven
Cheers!
steven
- tallkien
- 225 posts
- stevenong
- 1634 posts
- tallkien
- 225 posts
- stevenong
- 1634 posts
Hi there,
In the link to the thread I provided, you'll find the following:
Before you launch Houdini from a terminal make sure to set:
export LD_ASSUME_KERNEL=2.4.1
I believe you can also put this inside of the houdini_setup source file as:
setenv LD_ASSUME_KERNEL 2.4.1
It cleared up my glibc_2.0 problems that I ran into.
Houdini should run after setting the above.
Good luck!
Cheers!
steven
Good luck!
Cheers!
steven
- JColdrick
- 4140 posts
Can't seem to link to any of the threads, read all of them listed under Linux/ Redhat
Actually, I meant to point this out before. For some reason, the search function in the forums is a little wonky - it returns search results for the now-non-existant forums such as the open testing one from a few months ago. As tallkien pointed out, for “Redhat 9” you get all bogus responses…
J.C.
John Coldrick
- tallkien
- 225 posts
