Shell Problem
   2985   1   0
I used houdini shell application to ssh other machine. I can get into the folder, however, when I type hscript filename, it says the command doesn't exist.
What should I do? Thanks for help!
LanaSun
You need to source your houdini_setup script so it turns into a Houdini shell session.
