how to make mormals to a specified range.
4566 7 1- luoqiulin
- 303 posts
- asnowcappedromance
- 512 posts
you can calculate the length of the vector either in VOPs or with an hscript expression, or however you want to do it:
length (float x, float y, float z)
when you have length A and B you can subtract them to get the difference, which you then can add to each component of the shorter vector, that should give you matching lengths.
cheers,
Manuel
cheers,
Manuel
- luoqiulin
- 303 posts
asnowcappedromance
cheers,
Manuel
thank you, but i dont know weather i dont understand your idea or i have not cleared my mean.
i want set points' normal as the referenced normal, but with some rand offset
- keyframe
- 1532 posts
- luoqiulin
- 303 posts
- zarti
- 330 posts
- liuxiaolin
- 53 posts
If you already have an offset between ref normal, and now want to fit this offset to a certain range,you can compute its anglebetween, and fit range ,then use this resault angle to rotate it ,axis is the cross product.
if not, are you just want a random resault around ref normal? generate a random vector,cross production make it orthogonal with refnormal,and use it to rotate ref normal a random angle
Or use sin(rad)*normalize(randomOrthogonal)+cos(rad)*normalize(refnormal)instead of rotate().
- luoqiulin
- 303 posts
