Hi
I created a coin in the houdini.assign Mantra Surface Material(with Light & Object Reflection) to it.
I created a Mantra Node (Pixel Samples : 6 6 and image Size 1280 * 720 )
. but when I render the scene , Houdini Render some frames (for example 1 to 10 ) and after frame 10 Mantra Node Stoped with error.
when I take Mantra Node Info by MMB click on it I take below error :
Error : Command Exit Code : -1073741819
Why ?
Mantra Error -1073741819
3583 2 2- Sadjad Rabiee
- 1391 posts
- travisharkleroad
- 10 posts
I am also experiencing this error, using Houdini Master Education.
EDIT:
I discovered what was causing my error: animated FBX + sprite POP.
I'm not sure if that's relevant to your project, but when I switched from the animated FBX to a bgeo sequence, that fixed my render error.
I would still like to know what the error code refers to, for future reference.
EDIT:
- Sadjad Rabiee
- 1391 posts
really thanks my friend.
I have animated Carve SOP (with very large and long curve) and I attach a Coin to Curve's path.
maybe I have to export animated path on the disk and attach coin to this bgeos !
I used Mantra Surface for coin's material (with Displacement Map & Normal Map)
I used GI and Spot Light for lighting and turn on Irradiance Cache in the mantra node.but I don't know why I take error in some frames !?
