I watched the waterfall tutorial and use It for a project.
In this tutorial, there is a FLIP simulation used to render POP simulation.
The thing is I would like to have full automatic render.
I tried to use 2 fetch nodes in a ROPnetwork for this task ,linked to the DOP I/O nodes importing at SOP level each particles sim but the ROP render the 2 nodes frames by frames and I get a warning during the POP render phase :
/obj/flipSource_sculpted_fluid/import_flipSource_sculpted_setup/render: Awaiting 1 queued writes…
/obj/foam/import_flipSource_sculpted_setup/render: Awaiting 1 queued writes…
I think the solution should be to render node by node instead of frame by frame.
Changing in the render control panel Order option doesn't fix it.
Any help is welcome.
P.S. :
I need to setup initial state for the flip simulation.
How can I render .sim files inside a ROPNetwork ?
Urgent : ROP setting problem for simulations
1716 0 1- vbk!!!
- 383 posts
