polyBevel weirdness
   11942   20   2
Hi guys, I'm just starting to learn the basics of Houdini and I thought I'd start with the Quickstart tutorial on the SideFX website. I am following the steps exactly trying to build a Greek column from a cube. There is a bunch of edges that get a relative polyBevel and then some more edges after that get an absolute polyBevel.
Now here's where the problem happens, when I try to increase the repetitions of the second polyBevel I get corner edges extending right through the entire model and sticking out the opposite side like spikes. See attached images.
I have watched the steps in the tutorial several time and tried to replicate the steps, but each time I get the spikey edges.
Can anyone tell me why this is happening and is it something I'm doing wrong?
not sure why my images didn't work..? I'll try to re-attach them.
Try using a simple cube to practice on. See attached. You want to practice edge section < RMB , select loop or partial loop .
Rob
rse_abs_pbevel.hip (60.2 KB)
Gone fishing
Hey circusmonkey, I opened the file you sent me and it looks similar to the cube I was working on. Why does that spikey corner thing happen? I'm used to using Maya and bevels are no problem in Maya what-so-ever.
I followed the tutorial to a T and kept getting the weird corner spikes. If I knew what the problem was I could probably avoid it in the future.
Well clearly you haven't followed the instructions to a T . . I have no idea what your doing to get that shape. So I would be stepping back in my Houdini scene tree and working out which step you followed incorrectly. Practice on a cube until you get the hang of things
Rob
Gone fishing
Ok I tried just getting a basic cube, then I selected all edges and I applied a polyBevel with ‘high density round’ and in absolute mode. The same thing happens (see attached). Is it possible that something in the preferences is set incorrectly?
Unlikely. Download the latest build for what ever platform you are using and again practice on a cube
Rob
Gone fishing
that sample scene you sent me also had the spikey corner issue happening. How did you make that happen?
And i have that problem!
Whats wrong with PolyBevel????
i make video of simple wrong bevel from tutorial
http://youtu.be/1RaSmVz-R3Q [youtu.be]
and my nice cube
which build are you using?
it seems that some polyBevel issue has been fixed in 12.5.383
Tuesday, April 23, 2013
Houdini 12.5.383: Fixed bug with PolyBevel SOP that was producing incorrect output for bevelling either points or edges.
CG Supervisor
Framestore, NY
12.5.388 - ok
I'm using 12.5.316.22
so I just updated to the latest build 12.5.376 and it's still giving the same issue when using polyBevel. The result looks slightly different but it's still f'd up.
you have just updated to the latest Production build but as you can see that is 12.5.376
and the bug was fixed in 12.5.383 which is later so obviously you are still experiencing the bug
update to the latest build 12.5.389 or at least 383 to get rid of that
CG Supervisor
Framestore, NY
Ooops! my mistake. Ok I'll update again.
Ok I updated to 12.5.389 and problem solved 8)
389 on win??
i cant see 389 for win
Filter the results to Windows only.
glad that's sorted …. I had it working on h12.1 , H12 and the newest build.
Rob
Gone fishing
