hello,
I would like to know if it's possible to use lowrez fluid simdata as initial state of a highrez flip.
thx
question about simdata, flip resolution and initial state
2089 2 1- vbk!!!
- 383 posts
- zdimaria
- 390 posts
you can to some degree depending on what fields youve cached out. with just points, you can make a surface field from them and then scatter points inside and transfer the vel from the old points to the new points. if you have a surface field already this is easier. if you have a vel field you can resample that and use it, or just use it to init the vel on your points. the sim will take a bit to start behaving correctly and developing hi res detail, but itl work.
- vbk!!!
- 383 posts
I have vel field and surface field.
so if i understand I use surface field to create my points ( the same way than the ocean tool's “fluid tank initial” network)
then I can use my vel field within a source volume asset in dop.
right ?
oops, one last question :
how can i create a surface field from point ?
thx!
right ?
thx!
