Does anyone know why the expression function xyzdist has a return_type argument that allows you to query UV values while the VEX equivalent does not?
I'm trying to loop through a collection of points scattered in space and get the interpolated UV value of the nearest spot on a mesh.
Thanks,
Kevin
Why the difference between xyzdist in VEX versus Expressions
8750 5 1-
- KMcNamara
- 228 posts
- symek
- 1390 posts
Common for VEX functions is to have multiply signatures (while in hscript this doesn't work):
http://www.sidefx.com/docs/houdini12.5/vex/functions/xyzdist [sidefx.com]
- KMcNamara
- 228 posts
Hey, thanks for the reply.
I get that VEX functions can be overloaded, but there's no version with a return_type argument, so I can't get back UV values like I can with the expression function. Why the difference?
I have a random point in space and I want to get the closest UV value from a nearby mesh. Any idea how to do that?
- rafaels
- 702 posts
You could ray SOP the point onto the geometry and attribute transfer the uv…
It can also be done in VOPs and probably faster.
Toronto - ON
- symek
- 1390 posts
KMcNamara
I get that VEX functions can be overloaded, but there's no version with a return_type argument.
Second signature returns uvs and prim number in arguments (VEX's arguments are by reference in general):
float xyzdist(string geometry, vector pt, int &prim, vector &uv)
so (untested):
vector hitUV = 0;
int hitPrim = -1;
float dist = xyzdist(geometry, P, hitPrim, hitUV);
to get the distance, hit primitive number, and hit uv…
- KMcNamara
- 228 posts
Ah, thanks guys. Got it working with both VOPSOP and Point Wrangle. My main problem was that my mesh was storing its UVs in barycentric coordinates, so I had to convert these to the actual UV space.
For example, my point wrangle code:
vector primUV = 0;
int hitPrim = -1;
xyzdist(@OpInput2, @P, hitPrim, primUV);
vector finalUV = 0;
prim_attribute(@OpInput2, finalUV, “uv”, hitPrim, primUV, primUV);
@uv = set(finalUV);
vector primUV = 0;
int hitPrim = -1;
vector finalUV = 0;
@uv = set(finalUV);
