Is there a way to setup object render parameters so that an object is invisible but still casts GI? Or eg. invisible but receives shadows, or invisible but casts shadows?
I know that in maya you can setup these stuff in render section - receives reflections, visible in reflections, casts GI, receives GI etc.
render parameters
5742 9 1- andrej22
- 15 posts
- Sadjad Rabiee
- 1391 posts
- andrej22
- 15 posts
- Sadjad Rabiee
- 1391 posts
- andrej22
- 15 posts
- anon_user_37409885
- 4189 posts
- phrenzy84
- 249 posts
- andrej22
- 15 posts
Shadow eg - lets say I've got a box and a sphere which casts a shadow on a box and I want only the sphere and the shadow(which respects the shape of a box) visible in my render. Shadow matte shader is probably the solution though, I'm gonna try it out.
cast GI eg - lets say I got a background plate, an image of a mountain and lets say I wanna model a house which I would “put” on a mountain and I want the color of the mountain to bleed on the house, cast GI on the house. BUT, the mountain is just a background plate which I don't want in my renders, I'd add it later in comp. So I'd like to project the mountain image on a mountain geometry which I'd make just for the purpose of casting GI on my house. Basically I wanna have an invisible object that bleeds color onto my visible geometry. I hope that explains it a bit better now. Now, I know the workaround for this, I could just render it all with the mountain background plate projected onto geometry and use house objects alpha to cut it out in post, but I kinda wanna avoid that if possible and just render out the house which receives GI from invisible(during render time) geometry.
- Constantine Petrov
- 23 posts
Hi andrej,
For the second one, I'm doing exactly same thing in production shots right now where I need plate features to light and reflect in my CG geometry. So yes, I'm modelling the feature, then projecting UVs from camera, and then I just assign it a basic Surface Model shader with everything off but emission, where I put my plate exrs. And then I just check Phantom property on the object (if it's not there, you can add with Edit Parameters).
Works like a charm!
Works like a charm!
- andrej22
- 15 posts
I just tested it out. Actually “phantom” according to the manual makes an object invisible but casts shadows… but it also casts GI after I ran few tests. I didn't even have to use emission. Just made a mantra surface with diffuse RED, made a grid and a sphere sitting on top of it. Applied the red mantra surface to the sphere and turned on “phantom” on it and it was obviously casting shadows AND GI, I noticed the red color bleeding on th grid from the sphere.
