Hi all,
I'm trying to iterate over files in a folder and I can't seem to figure it out. My method so far is to try and add an attribute useing python, then use a foreach to iterate over it. But that's not really working, because I don't want to add an attribute to every point, prim or vertex…but I can only have a single entry for a detail attribute. (i.e. I'd need multiple entries for the fodlers).
Any ideas?
foreach iterate over files in folder?
9621 9 1-
- Anti-Distinctlyminty
- 271 posts
- pezetko
- 392 posts
- 271 posts
Thanks for the reply…this does seem to do what I want…except that I can't seem to get it to work when I modify it.
I can get a list of the files, but I seem to have some real problems with getting expressions/python to work in string parameters.
Most of the time it just fails and I don't know why.
Your python parameters show up as red, and when I take the same code and put it into another parameter, mine is not red and it doesn't work.
- pezetko
- 392 posts
To set python expression:
First put keyframe in parameter (it turns green).
Then in RMB menu switch expression language to Python (it turns red).
Also check if you are editing expression or result of it (Background color of Parameter's label show you if you are in editing or result mode. If there is different background color under parameter's label you are in editing mode). Left click on label switch between editing and result mode.
(If you edit python expression in result mode you got as result string with “quotes” at both sides instead of executable python code)
- 271 posts
Ah yes…I now have the ability to code python - thanks
What I'm having trouble with now though, is getting various parameters into other bits of python code. For example, I have this bit of code inside my for loop to determine the parameter called ‘fname’:
hou.node('../../control').evalParm('file')
Which returns something that looks like a python list, but if I then do something like
len(list(hou.pwd().evalParm('fname')))
it returns the length of the string…not the length of the list
Side note: I can never remember the correct expression to get the current index value inside a for loop. I'm currently trying
stamp(“.”, “FORVALUE”, 0)
But it always returns zero
Thanks for the help!
Edited by - July 2, 2014 16:59:53
- pezetko
- 392 posts
- 271 posts
Changed it to
len(eval(hou.pwd().evalParm('fname')))
and it works…the previous code, which is almost identical except for the ‘list’ part.
len(eval(list(hou.pwd().evalParm('fname'))))
I must admit, I'm confused as to why the top one works, but the bottom one does not. If the fname parameter returns a string, then passing it to a list should work ok…and if it returns a list object, then it should still work.
Any idea why it doesn't?
- pezetko
- 392 posts
I tested it today and you are right.
hou.pwd().evalParm('fname') returns string.
So then:
list(hou.pwd().evalParm('fname'))list() converts that string into list of letters.
But
eval(hou.pwd().evalParm('fname'))interprets this string as python code and evaluates it.
Compare:
string = ""
print list(string)
print eval(string)
I'm sorry for confusion in previous post.
So then:
But
Compare:
string = ""
print list(string)
print eval(string)
- 271 posts
I've tried implementing this, but I've run into another problem - it is insanley slow.
So slow, that I've had to cancel it before it has completed.
Currently, I'm trying to create a string attribute, copy the file name to it using copy stamping, then use it later. But it just takes so long that it's completely impractical, and I really don't know what the problem is.
I've attached my latest attempt - obviously you'll have to change the folder directory and extension.
- pezetko
- 392 posts
It depends what you want to do.
You can cache result of foreach sop. You can set Max Iteration to one, test your setup and then run it overnight on all files.
Or you can insert file sop inside foreach sop, do your stuff on single loaded object and save it with another file sop, all that still inside foreach. So you can make simple file converter this way.
You can also use a little different technique, create points, load file paths and save it as string attribute on points. So you will end up with couple of points where each have attribute pointing to different path. Then you can use this attribute to load only desired files (iterate over points, delete unwanted points etc..)
Look at this video: https://vimeo.com/99354544 [vimeo.com]
