When I drag in a curve decorator OTL into Unity, I don't see any curve to edit.
When I draw a curve for the decorator, it's very sluggish moving the points.
What I want to do is draw or edit the default curve (if I can get it to appear)
to run along my dungeon corridors. Why isn't the default curve visible like in
the videos?
curve decorator question
4558 3 0- terrymorgan
- 7 posts
- damian
- 402 posts
- terrymorgan
- 7 posts
You can see by the screenshots there's a curve there I made, I can use it for curve decorator, however the default'curve decorator'
curve doesn't display.
Obj(id: 1, name: path): Invalid argument given: Tempated geo did not cook. Geo info may be out of date.
Object Path: /obj/CurveDecorator2/path
UnityEngine.Debug:LogWarning(Object)
HoudiniAssetOTL:buildCreateObjects(Boolean, HoudiniProgressBar&) (at Assets/Houdini/Scripts/HoudiniAssetOTL.cs:208)
HoudiniAsset:build(Boolean, Boolean, Boolean, Boolean, Boolean, Boolean, Boolean) (at Assets/Houdini/Scripts/HoudiniAsset.cs:1221)
HoudiniAssetOTL:build(Boolean, Boolean, Boolean, Boolean, Boolean, Boolean, Boolean) (at Assets/Houdini/Scripts/HoudiniAssetOTL.cs:123)
HoudiniAsset:OnEnable() (at Assets/Houdini/Scripts/HoudiniAsset.cs:769)
- damian
- 402 posts
Right. I see the problem now, though I'm not sure how you got into that state. I can't reproduce it on my end.
In any case, it seems our curve decorator asset has a templated SOP in it that's causing problems for you.
I would say either get tomorrow's build of 14.0 (because I fixed the template thing) or turn on Import Templated Geos for your curve decorator asset. This is an option in the Inspector under Asset Settings > Cooking tab.
