How to get flip fluids colliding?
2661 8 2- lee_jackson
- 26 posts
- Skybar
- 166 posts
- Sadjad Rabiee
- 1391 posts
- lee_jackson
- 26 posts
- lee_jackson
- 26 posts
Joker386
You have to use only 1 FlipSolver with two different emitter for colliding with each other , Also add another Source Volume DOP, check attached file :wink:
This is where I'm running into problems, I can't successfully get the two emitters running through the one one flip solver without running into errors, is there specific way I should be creating the second emitter?
- lee_jackson
- 26 posts
- Sadjad Rabiee
- 1391 posts
- Sadjad Rabiee
- 1391 posts
- lee_jackson
- 26 posts
Joker386
You should create second emitter manually .
1. Create another object for new emitter
2. Copy create_surface_volume , merge_surface_volumes , OUT_surface from first emitter to new emitter
3. in the AutoDopNetwork copy source_surface_from_box_object1 and connect new one to the merge3
This is exactly what I ended up doing, thanks for helping.
