Creating random rotations
   5423   7   2
Hi all, I am following this tutorial (https://www.sidefx.com/index.php?option=com_content&task=view&id=2166&Itemid=361 [sidefx.com]) on the first part - rock generator.
Using that same exercise, I am trying to create random rotations onto the rocks. I have been reading some ways to do so, such as using point SOP, polyframe etc.. but I am unable to get it right
I used a Point SOP, creating random normal directions, thinking it may work but it ain't. Can any one guide me?
Many thanks in advance!
EDIT: Attached file for references
Edited by - June 3, 2015 02:48:16
ex05_rocks.hip (113.0 KB)
here is example of using Attribute Randomize SOP to randomize pscale and orient attribs on points to randomize copies or instances
randomize_copies.hip (120.3 KB)
CG Supervisor
Framestore, NY
Hey tamte, thanks for getting back to me.
By the way, I am having issues opening the file, and got the following error as seen in the attachment.
3 nodes, namely - attribrandomize_pscale, attribrandomize_orient and the copy are in Red. Am I perhaps missing something?
By the way I am using Houdini 13
By the way, I was told, quoted by one of my colleague that some Houdini stuff were removed in the office version of the Houdini that I am using, probably that is why it is not working.. What it is, I may never know…
But even so, is there perhaps another way of doing so, by using the file that I have attached in my first post?
salik
This project made by Houdini 14 , I think you have Houdini 13 or older versions :wink:
Rabiee.Sadjad@Gmail.Com
We have couple ways for doing that , however I made some of them for you in H13 (if you don't have H14 !) :wink:
JK_Rand_Rot.hip (243.6 KB)
Of course as salik said , in the Houdini 14 you can use Attribute Randomize node , But you don't have this in Houdini 13 , So you should make it manually with one of the methods that I made :idea:
Joker386
Hi Joker386, sorry for the late reply. Just tried out your file and it is working for me and indeed what I am looking for!
Greatly appreciated it!
