Hi!
I just bought the ProTrack Bundle from the Unity Asset Store but I can't make the plugin work. I have run through the forum but haven't been able to find a way to solve the problem.
I can see the Houdini Menu in the Unity but when I try to use a sample file to test I get an error:
DllNotFoundException: libHAPI
and
HoudiniHost.getEnvInt (HAPI_EnvIntType int_type) (at Assets/Houdini/Scripts/HoudiniHostWrappers.cs:56)
If I click the Houdini Debug menu item in Houdini Engine tab it says that “You are missing the Correct Houdini (14.0.357) with Houdini Engine (1.9.20) installation.”, but I don't know what to do to correct that.
I have read the troubleshooting part from the Houdini Engine 1.9 site here: http://www.sidefx.com/docs/hengine1.9/_h_a_p_i__plugins__unity.html#HAPI_Plugins_Unity_Troubleshooting, [sidefx.com] but without no luck.
I have Windows 7 Professional, Unity 4.6.5 Pro(32-bit), I have tried both Houdini installers 14.0.335(32-bit) and 14.0.357(32-bit), I have put “C:\Program Files (x86)\Side Effects Software\Houdini 14.0.357\bin;” in the PATH environment variable also.
I hope someone can give some helping thoughts, thank you.
Error DllNotFoundException: libHAPI...
4677 3 0- Jeppe Tukevainen
- damian
- 402 posts
- aeaeaeae
- 128 posts
- damian
- 402 posts
This was a user-specific issue. Something was wrong with his system environment. We never got a resolution though as the replies stopped. Not sure what happened.
What exactly is the error you're getting? It may not be the same thing. If it is DllNotFoundException: libHAPI, have you tried the troubleshooting steps at: http://www.sidefx.com/docs/hengine1.9/_h_a_p_i__plugins__unity.html#HAPI_Plugins_Unity_Troubleshooting [sidefx.com]
