Nodes using Python Source Editor in subnetwork
   2203   2   1
I have a couple nodes that work with a CHOP network and they in turn use functions I have defined in the Python Source Editor.
All works fine, but once I put those nodes and CHOP network together in a subnetwork they no longer are able to work.
Is there a way to change this, or is it a ‘normal’ limitation?
Thanks for any feedback
Do you have relative paths somewhere? There's no reason the code shouldn't continue to work no matter where the nodes are, as long as they are all using valid paths.
Hi graham:
No I wasn't using relative paths, only “channel reference” option as opposed to “Relative channel reference”
I'm including a few screenshots…one of the error messages and the others that refer to the error message. There are more references in the “chain” of channel referencing but they all refer in the same manner with “channel reference” and the functions are all prefixed with hou.session.
