substance-in-houdini how get it to work with renderman ?
“The Substance shader communicates directly with the Principled Shader, and the Mantra Surface shader is available on an experimental basis. In the same way, it is possible to describe the interfacing with any other shader via a description file. You can set the shader choice in the plugin options.”
1608 0 1- gfxfx
- 91 posts
