Can't load dxf, .obj as well as .stl files!
Get the error
Error: Unable to read file …
The only geometry files that seem to load without error are .bgeo and .fbx files.
Also I upgraded to latest build 15.5.632
Possibly related to a corrupt config or other file in my $HOME directory?
Also tried removing spaces from filenames and moving the geometry file to C:\ to eliminate pathing errors
Running Windows 10.
Error: Unable to read file [.obj, .dxf, .stl]
5650 7 2-
- art3mis
- 351 posts
- malbrecht
- 806 posts
Moin,
just to be on the safe side - have you tried with a trivial OBJ file, like a single triangle, hand-written into the .obj? If that also fails, there must something odd (at least I can, without any issues, import some obj test files here into 15.5.632).
If it does *not* fail, there's still the chance that your files are corrupt in some weird way, although that sounds unlikely for several different files …
Marc
Marc
Edited by malbrecht - Nov. 28, 2016 03:16:26
Good bye.
Good bye.
- blackpixel
- 182 posts
- art3mis
- 351 posts
- malbrecht
- 806 posts
The file references “Nymph.stl”, which I do not have … simply loading another obj from the file node works fine here.
Marc
Marc
Edited by malbrecht - Nov. 28, 2016 08:14:50
Good bye.
Good bye.
- art3mis
- 351 posts
- malbrecht
- 806 posts
> Maybe some 3rd party otl I've installed or?
would be interesting to know how a 3rd party tool interferes with a clean Houdini installation (which is what you did - at least in my understanding) … still, it seems to be something machine-specific.
Marc
Marc
Good bye.
Good bye.
- art3mis
- 351 posts
